Tach Zero
Old Feb 22, 2006 | 09:58 AM
STXHANK's Avatar
STXHANK
Default Tach Zero
My tach does not zero. Is it a simple matter of pulling the needle and setting a zero? What is the simpliest way ofgetting the tach out to do this.
Old Feb 22, 2006 | 08:50 PM
LiveandLetDrive's Avatar
LiveandLetDrive
When does it not go to zero? Does it zero when you have the key in the on position, but the engine off? I think most (electrical ones that is) stick at idle speed unless you click it back on for a second after shutting it off.
-Chris
Old Feb 23, 2006 | 02:38 PM
STXHANK's Avatar
STXHANK
When the key is on the need rests at 300 rpm...
I imagine all tach readings are 300 rpm higher then they should be.
To Tach Zero
