Heat from Headers
Old Feb 23, 2006 | 03:48 PM
c3andc5's Avatar
c3andc5
Default Heat from Headers
My headers put off an incredible amount of heat and my spark plug boots & wires are very close. I don't want that to become a problem. Anyone know where I can get spark plug boot heat protectors like those that come on the C5s?
Old Feb 23, 2006 | 03:55 PM
Kalway's Avatar
Kalway
Summit has em. Just do a search on their page for "boot protectors"
Old Feb 23, 2006 | 06:20 PM
71redskin's Avatar
71redskin
got mine from a speed shop if you have one nearby.
Old Feb 24, 2006 | 05:48 AM
guppie's Avatar
guppie
St. Jude Donor '08
You might also go to the shorter plugs Accel makes, that will give you a little more room. I know I had to go to them
Old Feb 24, 2006 | 06:27 AM
73jst4fun's Avatar
73jst4fun
go to Summit or Jegs they have the boots, I use them, also the header wrap you can use..........it works.......
Old Feb 24, 2006 | 07:45 AM
norvalwilhelm's Avatar
norvalwilhelm
This is a post I ran a while ago on header wrap. I really like the stuff. My headers stay really cool
I have run Hedman wrapped headers for at least 10 years without a problem. I decided to upgrade my headers with hedman again and since they don't make their elite header in 2 inch for the bigblock I went with the normal 2 inch header and wrapped them. It takes a complete 50 foot roll per header.
The big thing with using wrap is to soak it well before using. Once wet it is very pliable and you can stretch it tight for a good fit and I found if double wrapped at the start you do NOT need clamps. My last wrapped went the 10 plus years without unwrapping, Once dry it holds it new shape.
Wet it well and it will wrap really nicely.
The wrap allows me to touch the tubes almost as soon as I shut the car down. It prevents starter soaking and that blast of hot air you get when you pop the hood at car shows after a long drive.
Notice the cut in the flange. I do this between each set of tubes. I cut with a hacksaw nearly all the way through. This allows the flange to flex allowing the header gasket to seal better. I then use normal cheap gaskets and high temp silicon. My headers don’t leak.
Old Feb 24, 2006 | 07:57 AM
PatsLs1vette's Avatar
PatsLs1vette
i wrap mine also i can have a plug wire sitting on it and nver burn and touch the pipes almost right after shut off.
Old Feb 24, 2006 | 09:30 AM
Lee H's Avatar
Lee H
I'm using MSD wires. They are about 3/4 inch from the headers and seem to be OK. Only a few thou miles so far. I'm sure they are many who have lots of miles with this combo, any comments????
Old Feb 24, 2006 | 09:34 AM
Fubba's Avatar
Fubba
I use 90* plugs with wire looms and my wires are fine.
Old Feb 24, 2006 | 09:55 AM
Hvymtlc5's Avatar
Hvymtlc5
as Norval say the header wrap works very well (I tried it for the first time on my project BB)..I'm pleased with the results. You can buy the wire insulating "socks" from ebay too. Advance Auto has started carrying them and they are much cheaper than most speed shops.
Old Feb 24, 2006 | 10:02 AM
CGGorman's Avatar
CGGorman
I'm using Jet Hot on the headers and DEI "socks" on the plug boots. No problems. I got the socks at my local speed shop.
DEI sells a couple different solutions for this problem. http://www.designengineering.com/pro...sp?m=sp&pid=54
Best of all, they're American Owned / American Made.
Old Feb 24, 2006 | 12:16 PM
71redskin's Avatar
71redskin
norval, i was gonna get the wrap when i ordered my hedmans but the tech said wrapping the em voids the warranty and promotes rust when they get wet.
Old Feb 24, 2006 | 12:37 PM
markdtn's Avatar
markdtn
As a side note, if all that heat is damaging your plug wires, watch what you are doing to the steering box. You can cook the oil inside if it gets too hot.
Old Feb 24, 2006 | 03:06 PM
c3andc5's Avatar
c3andc5
I do have Accel plug wires which I like, but they are still very close to the headers.
Old Feb 24, 2006 | 03:10 PM
c3andc5's Avatar
c3andc5
[QUOTE=norvalwilhelm]This is a post I ran a while ago on header wrap. I really like the stuff. My headers stay really coolQUOTE]
I have the same wrap, but was concerned with the possibility of trapping heat & moisture. Any thoughts on that?
Thanks,
Chris
Old Feb 24, 2006 | 03:12 PM
c3andc5's Avatar
c3andc5
Yep, that's the other reason why I wanted to wrap my headers, but concern about trapping heat & moisture caused me to reevaluate.
To Heat from Headers
