Please help with Hooker side mount header install on a BB.
I started putting the driver side header on tonight and I cannot get the bolts started. Did any of you have to clearence the flanges at all to clear the lower head bolts? it also seems that the manufactured dent for clearing the steering gear box might not be dented enough. I have only been able to get the front bolt mounted.
I didn't have any problems but I'm running GM heads. I know some people had to have the heads modified because they had problems w/ raised exhaust ports. I see you have Edlebrocks, aren't they std/oem sized ports?
I just did this Sunday,do you have help or by yourself?If you can get some one under the car and jigglle the header it'll go.
mine has no clearane to box with out dent
Thanks guys.
I removed the rockers to do the test fit so that is not a problem. The Edelbrocks are an OEM style casting without raised exhaust ports. I will try an get the wife to help me out a bit Saturday on the driver side. I will go ahead and try the passenger side on my own again.
Silly me!! And hear I was thinking that this was going to be an easy job.....
you may have to elongate the bolt holes in the flange...check the holes with the exhaust gasket. You might consider dropping the steering box if you have trouble lining up the bolt holes
I put mine in by myself. No dings to clear anything. On GM/Edel heads that come with ZZ502 engines the bottom headbolts can be replaced with a 12 point ARP bolt that are short enough not to interfear with the header flanges so youdont have to grind on that pretty Jethot Coating. Studs would have a similar clearance requirement I would think but griding would be your option there...
This was all revealed to me by the Oracle that is the Corvette Forum Search command
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I had to get the "low head" ARP bolts for the stock exhaust manifolds.
I had no problem with the lower studs hitting the flange, but I did have to hog out the bolt holes...guess that raised the header enough to clear the lower studs.
