mystery engine numbers
Old Aug 11, 2001 | 12:22 PM
ykp53's Avatar
ykp53
Default mystery engine numbers
i need some help identifying a engine. The distribuitor is located in the rear of the engine and it goes through the intake mainifold, so im pretty sure its a chevy engine, but there are no numbers located on the block pad, and the only thing i can find stamped on the block is " k21, 445, hi perf, pass" this is located near the oil filter. does any one know exactly what i have found? :confused:
Old Aug 11, 2001 | 01:41 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: mystery engine numbers (ykp53)
sounds like it could be a big block motor by the hi perf pass down near the filter...but others might no best.
Old Aug 11, 2001 | 02:15 PM
ykp53's Avatar
ykp53
Default Re: mystery engine numbers (pats406nitrovette)
thanks for trying to help, i went checking and found a few more casting numebers, by the bell housing on the drivrs side is 14015445 g 2p. im sure this will make thing more confusing.....
Old Aug 11, 2001 | 02:41 PM
PatsLs1vette
its 78-90 454 block 2 0r 4 bolt main
if you need help with casting numbers go to http://www.mortec.com
[Modified by pats406nitrovette, 1:45 PM 8/11/2001]
To mystery engine numbers
