12Volt source for electric choke.
Old Aug 11, 2001 | 03:31 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default 12Volt source for electric choke.
I just removed my Q-jet to send it off for a rebuild and setup. I have a Holley 650 that I'm going to put on the car fro the time being. I need to find an ignition powered 12v source for the carb. Any one have any clues were to look for a good wire to tap?
Old Aug 11, 2001 | 03:36 PM
PRNDL's Avatar
PRNDL
Default Re: 12Volt source for electric choke. (Smokehouse69Mark2)
Steve, did you see my post about the corvettemagazine.com article?
or.... did you see the article about replacing qjet with holley? They just had an old wire hanging around that they hooked up! so, that doesnt really help you! but more to the point.... I dont think you are supposed to torque your carb to 65 lbft as per the article.. :eek: MJ
Old Aug 11, 2001 | 04:36 PM
theandies's Avatar
theandies
Check your fuse box. There should be a post in the fuse box that says ING on it. At least it has it in my 71's box. I used this post for my MSD 6AL box and works just fine.
John
Old Aug 11, 2001 | 04:43 PM
nunus79's Avatar
nunus79
Steve
I've HEARD that you can tap off of the windshield wiper motor power lead. Hopefully someone who has done it will ring in.
Old Aug 12, 2001 | 12:51 AM
glen242's Avatar
glen242
Default Re: 12Volt source for electric choke. (nunus79)
Mine is hooked into the wiper terminal block. The middle one, I think, is only hot when the key is on. Use a meter and check.
Old Aug 12, 2001 | 12:55 AM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
On my '80 that came with electric choke it's one of the wires coming out of the harness from the alternator.
Hope that helps
Old Aug 12, 2001 | 01:20 AM
79 vette's Avatar
79 vette
I have mine connected to the winshieldwiper motor same as glen242
Old Aug 12, 2001 | 01:23 AM
john73bb's Avatar
john73bb
Default Re: 12Volt source for electric choke. (79 vette)
I suggest that you tap into your oil pressure somewhere with a pressure activated switch so that the choke only gets power when the engine is running. You don't want your choke going off before you start the engine just because you left the key on for a while.
To 12Volt source for electric choke.
