Valve Clearance?
Old Feb 25, 2006 | 03:36 AM
Tumarr's Avatar
Tumarr
Default Valve Clearance?
Gonna try this question out with the c-3 guys....
I am putting together a 383 and had a question about clearance for the valves. I am considering using a mechanical roller cam that has about .580-.6 lift. I am almost positive that there will be issues with the valves hitting the pistions due to the unconventional layout of the valves in my heads. My heads are Trickflow twisted wedges. What I wish to know is, is there a tool I can use to grind proper valve reliefs into my pistions so that I will have enough clearance? such as a cutting bit the same size as the valve and bolt the head on and lower it onto the piston to grind the reliefs. maybe I can just sharpen a valve and use that as my cutter. Is this a smart way to do this?
Old Feb 25, 2006 | 07:20 AM
Gordonm's Avatar
Gordonm
I have seen a tool for this and used one once. It looks like avalve and has cutting grooves in it. Measure the valve to piston clearance first before you start grinding on the pistons. You want .100 on the intakes and .125 on the exhaust to be safe. You can go tighter but these are safe numbers.
Old Feb 25, 2006 | 10:14 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
I would try and find a local machine shop. They probably have the tool.
Old Feb 25, 2006 | 10:56 AM
ltlevil's Avatar
ltlevil
There is a setup you can use that fits where the valve normally would in the head. The head is mocked up on the block and a drill can be used to cut the valve reliefs, the valve guide is used to ensure everything is removed where the valve will actually ride. It also has a stop on it used to ensure you don't cut too much. It's actually pretty straight forward but is a little bit of a pain and takes some time, but in this area I don't mind taking my time.
ltlevil
Old Feb 25, 2006 | 09:37 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You can get the tool from Iskendarian. Works well..takes some time...but works nice.
JIM
Old Feb 25, 2006 | 09:45 PM
GDaina's Avatar
GDaina
Speed shop can cut the valve reliefs....if you do this yourself, be careful not to cut too deep
To Valve Clearance?
