Calculating displacement?
Old Feb 25, 2006 | 12:30 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Default Calculating displacement?
Following up on a post in general.......when you bore a 454 .30 how is the displacement figured? Volume of a cylinder is V= p r2 h or pie x radius squared x height. Can someone fill in the measurements? When thee bore is .30 over the post said it engine becomes 460 but .60 over it becomes 468. If the bore increase is .30 how can there be a difference of 6 cu in. to 8 cu in.? 454 vs 460 vs 468
Old Feb 25, 2006 | 12:39 PM
David Ey's Avatar
David Ey
The increases are proportional not linear. Try your math using only the increase numbers....you will see that the result of the .03 test times 2 does not equil the .06 test.
Old Feb 25, 2006 | 12:42 PM
Don Rickles
2017 C3 of Year
Originally Posted by David Ey
first, that would be .03 and .06 rather than .30 and .60
I realized the typo after posting
Old Feb 25, 2006 | 04:33 PM
jerrylee's Avatar
jerrylee
Default 454..
.30 over would give u a 4.28 bore with about 460 cubic inches n were in pa. r u...if u go 2 roadster.com there is a ton of big block info.....good luck....
Old Feb 25, 2006 | 04:45 PM
jerrylee's Avatar
jerrylee
Default 454 bore...
if u do a 30 over bore u r increasing the cylinders by 300th's of an inch wich will give u an increase of about 6 cubic inches of air/fule mixture....40 0ver will give u about 462 c.i. but these r not an exact science because the stroke also comes into play here....anybody else have some input...
Old Feb 25, 2006 | 05:13 PM
aussiejohn's Avatar
aussiejohn
Default aussiejohn's Universal Capacity Formula
G'day,
Not much help to you big block guys, but I have discovered a universal method of determining capacity for any V8 engine with a 4.000" bore. The formula is:-
Capacity = stroke x 100 +2
Take a 350 Chev, stroke =3.48", multiply by 100 = 348, add 2 = 350.
327 has a 3.25" bore, multiply by 100, = 325. Add 2 = 327
Same with 302, 3.00" bore x 100 =300 +2 =302.
Chrysler 392 had 4.00" bore x 3.90" stroke, a Holden 308 has a 4.00" bore and 3.0625" stroke, etc. etc.
Now look at a Ford "351" (Cleveland or Windsor) with a 4.00" bore and a 3.50" stroke. According to the formula, its actual capacity is 352 cubic inches. No wonder they have trouble getting their stuff to work properly.
Regards from Down Under
aussiejohn
Old Feb 25, 2006 | 05:32 PM
StickShiftCorvette's Avatar
StickShiftCorvette
Originally Posted by aussiejohn
G'day,
aussiejohn
This is really bizzarre way of looking at the world!!
Displacement is porportional to the SQUARE of the bore.
The Assie constant for 4" bores is actually 100.531 and just eliminate the +2 fudge factor
=8 * pi * (4*4)/4
The universal equation for 8 cylinder displacement is:
Displacement=8 (cylinders)*Stroke in Inches *(3.1416(pi)*((Bore in Inches)*(Bore in Inches))/4
This is 8 cylinders times the stroke times the area of one cylinder (=pi *d^2/4=pi * r^2 (pi(e) diameter squared divided by 4 = pi(e) radius squared)
350 Chevy= 8 * 3.48 * 3.1416* (4*4)/4 = 349.85
454 Chevy= 8 * 4 * 3.1416 *(4.25 * 4.25)/4 = 453.96
350 .030" overbore Chevy= 8 * 3.48 * 3.1416* (4.03*4.03)/4 = 355.11
454 .030" overbore Chevy= 8 * 4 * 3.1416 *(4.28 * 4.28)/4 = 460.39
Simple Math......
Old Feb 25, 2006 | 05:33 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
G'day,
aussiejohn
you have me all confused now. the 350 you use the stroke and the rest you use the bore. now if i use the bore for my 350 it would be a 402 sense my bore is 4.000"
Old Feb 25, 2006 | 06:20 PM
aussiejohn's Avatar
aussiejohn
Default formula again
Stickshift,
Of course you have the correct "exact" formula, but only a very small miority of people can work that out without a calculator. My formula works perfectly for any eight cylinder engine within one cubic inch, providing it has a 4.000" bore. Period.
Liquid,
Sorry to confuse you, of course I made ONE mistake. With the 327 engine, I said "3.25" bore" when I meant 3.25" STROKE. All here should know that 302's, 327's and 350's ALL have a 4.000" bore, and my formula works for them all, even the "383". Most engines here use a 350 block and a "400" crank which came from an engine with a 3.125" bore and a 3.750" stroke. Put that 3.750" stroke crank in a stock bore 350 block and you have, according to my formula, 377 cubic inches. And that is true, but most people who do this also bore the engine out to say 4.030" and it is this increase in bore that gives a final displacement of 383 cubic inches.
aussijohn
Old Feb 25, 2006 | 06:24 PM
LIQUIDDRAGON
Stickshift,
Liquid,
aussijohn
i was thinking that that is what you ment to put but i wasnt 100% sure and i didnt want to assume so i was just waiting for your response and now it makes sense to me and i understand the formula 100% now its and easy formula to use as well. thanks
Old Mar 1, 2006 | 02:30 AM
aussiejohn's Avatar
aussiejohn
Default reply
LIQUID,
Thanks for the reply, I'm glad that you now understand it. I remember when I first started on this Forum about three or four years ago, there was a popular saying that I haven't seen for a while:-
"Knowledge gained and not shared is knowledge lost."
I heartily concur.
aussiejohn
Old Mar 1, 2006 | 09:46 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
LIQUID,
I heartily concur.
aussiejohn
I like your rule of thumb my friend from down under, will make for a good discussion at the local watering hole with my gearhead friends tonight
tim
Old Mar 1, 2006 | 10:31 AM
sly vette's Avatar
sly vette
try this
Later,
Sly
To Calculating displacement?
