Interior light problem
Old Feb 25, 2006 | 06:32 PM
Beater's Avatar
Beater
Default Interior light problem
After pulling out the interior in my 79 to weld in new floor pans, I've been chasing electrical gremlins.
Currently I have no interior(dash) lights. I replaced the headlight switch as I broke the original removing it with more brawn then brains. Afterwards I was blowing the fuse to the tail lights evry time I clicked the lights on. I noticed a little copper jumper on the new switch that connected pin 4 (or 5?) to pin 3. I removed that and the fuse stopped blowing .
Only afterward did I realize I now have no interior lights. I have a mini mag light duct taped to the steering wheel for now.
Has anyone else had similar problems? Moreover, was that copper jumper really important? I've been playing with the switch and my multimeter and have found the battery connection only connects to the headlight pin. Pin 2 & 3 seem to connect through the rheostat for the dimmer.
All the gauges work as well as the ever have and a continuity check seems to rule out a bad ground.
My wiring diagram has meet it's match with this one.
Old Feb 27, 2006 | 09:43 PM
Beater's Avatar
Beater
Ok so a bad ground is definately ruled out now.
Does anyone else have the previously mentioned copper jumper on thier switch?
Old Feb 27, 2006 | 11:21 PM
StickShiftCorvette's Avatar
StickShiftCorvette
When you blow fuses the issue is NOT a bad ground but a short. You need to find where your wiring is grounding out. Any point in the lighting harness or a short in any socket (or bulb itself) can do it.
If a '79 still has separate bulbs, you should pull them all out, put in a new fuse and then see if the fuse blows when you turn the dash lights on. If so, you need to go deeper into the harness. If not, install the lights one at a time until you find which one blows the fuse.
Good hunting.
Old Feb 28, 2006 | 10:55 AM
palazzopl's Avatar
palazzopl
looking at my print for an 81 the tail light fuse also supplies power to the instrument lights.. I think the harness go thru the console or down by the left kick plate
Old Mar 2, 2006 | 01:54 AM
Beater's Avatar
Beater
Ok thats what I need to know. Looks like I'll have to patch into the tail light circuit some how since I can't find that copper piece. I think the blown fuses may have been because the contacts on the printed circuits of the dash were coming lose and might have crossed. I've since reglued all the contacts in place.
Back to the drawing board I guess.
Old Mar 2, 2006 | 02:08 AM
tfi racing's Avatar
tfi racing
Does your car have a delay timer for the interior lights(not the cluster lights)?If it is bad or missing the dome light(s) will not come on.
Old Mar 2, 2006 | 10:47 AM
Beater's Avatar
Beater
Sorry dude, but did you even read the thread?
Anyhow, here are some pics of the current state of things since everyone here loves carnage.
Old Mar 2, 2006 | 12:50 PM
icanfixitforyou's Avatar
icanfixitforyou
Oh my Gawd.....
Old Mar 6, 2006 | 09:22 PM
Beater's Avatar
Beater
I've said that more times than I can count with this car.
Old Mar 6, 2006 | 09:31 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
this guy did an excellent job of scanning good info..it's an '80, but should be very close..
he has wiring diagrams and a ton of helpful shet...
by the way, did anyone mention ...just damn?
Old Mar 6, 2006 | 09:58 PM
Beater's Avatar
Beater
Thanks for the link. I actualy have the GM service manual that all came out of. I'll have to dig at it more later. I have the diagram from lectric limited (got it at the last bloomington gold). It has been my most valuable buy yet. If anyone else has electrical issues, get one.
To Interior light problem
