BW T-10 transmission size?
Old Feb 26, 2006 | 03:13 PM
Duke94's Avatar
Duke94
Default BW T-10 transmission size?
I'm going to rebuild the 4 speed in my 78'. Got the overhaul manual out, and it lists 3 different 4 speeds: 76MM, 83MM and 117MM. How do I tell what I have?
Old Feb 27, 2006 | 10:35 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I'm not entirely sure what that is referring to. Do they specify what is supposed to be 76mm, etc?
Old Feb 27, 2006 | 08:38 PM
chewy's Avatar
chewy
Unless it is something to do with ratios? Does it show 3 different trans?
Old Feb 28, 2006 | 10:07 AM
Duke94's Avatar
Duke94
Since 76MM is 3" so I'm thinking it could maybe the diameter of the flange that mates up to the bell housing. The pictures of the 76 and 83 MM look simular, but the 117MM trans must be a truck since the shift lever comes out the top of the trans. (I don't have the trans out yet to measure anything)
To BW T-10 transmission size?
