lock up or not
Old Feb 28, 2006 | 08:01 AM
rastadr's Avatar
rastadr
Default lock up or not
im about to go for the converter and the locals here seem to all agree that the additional 2-300 rpm drop on the highway over 4th gear (700 r4) isnt worth the problems/expense/hook up costs and additonal exposure to future breakage of the lock up feature. i like the idea of lower r's on the highway but it seems more predictable to not use lock up. id appreciate guidance.
Old Feb 28, 2006 | 09:01 AM
shafrs3's Avatar
shafrs3
Art Carr is a pioneer in building OD tranmissions for the performance market says no to the lock up converter. I took his advice and didn't have problems with mine.
Old Feb 28, 2006 | 09:05 AM
SIXFOOTER's Avatar
SIXFOOTER
Check out what these guys have to say about it. Lots of performance cars come from the factory with lockup working..
http://www.700r4.com/tech/index.shtml
Old Feb 28, 2006 | 03:53 PM
MIKER's Avatar
MIKER
The typical advise is that your transmission will run hotter without lockup for obvious reasons. However, I'm confident that running without lockup will not damage anything so long as you have a trans cooler that will keep the operating temperature from becoming excessive.
Old Feb 28, 2006 | 05:09 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Default Lock up
I have a 700r4 in my 69 convert. I use the lock up feature on the highway. Mine is wired to a switch in the cockpit and thru the brake light switch. I can disable it when cruising at slower speeds if I want. As far as running hotter, I will know more when summer gets here to FL.
Old Feb 28, 2006 | 05:58 PM
Kalway's Avatar
Kalway
As long as the transmission stays cool it's not a big deal, but it's a nice feature to use, still. TH-350s ran forever without them.
Old Feb 28, 2006 | 06:00 PM
comp's Avatar
comp
what kind of HP you running to it ???
Old Feb 28, 2006 | 06:07 PM
Kalway's Avatar
Kalway
Too much power and hitting the throttle hard after lock-up could result in some costly effects.
Old Feb 28, 2006 | 08:57 PM
kevinator80's Avatar
kevinator80
Do you guys have any opinion about hydraulic lock up? I was looking at Maddog trans. site on ebay last week and he said he could set up a hydraulic lock up with no wiring required. Ever heard of this?
Old Feb 28, 2006 | 09:50 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
hey Mike ever change that shift detent??? i agree with MikeR if you have a trans cooler it will probalby never be an issue.....whats your stall speed going to be? if it is less then 2000 you probalby will be close to stall speed at 70 mph if you have a 3.08.....on my car with a 2500 stall speed and 3.08 it still has lots of "float" at 75+ with the lock up turned off
Old Mar 11, 2006 | 04:24 PM
MIKER's Avatar
MIKER
My 700R4 was set up that way initially but suffered an unrelated failure within 1000 miles. I cannot say with complete certainty but It's my impression that this is not the manner preferred by most hi-performance trans builders for lockup control.
Originally Posted by Bob
...hey Mike ever change that shift detent???...
Hey Bob! No, I'm neck deep in the repaint project. After that I will redo the interior along with modifying the shift plate to allow use of 1st gear.
Old Mar 11, 2006 | 04:44 PM
norvalwilhelm's Avatar
norvalwilhelm
I liked my lockup but it was done manually. I pressed a button and the lockup engaged, Touched the botton a second time and it disengaged or touching the brake also disengaged it.
I did have problems with breaking the lockup loose under hard usage but it did pull the rpm down a few hundred rpm.
To lock up or not
