So based on what I am reading, for my 100% stock L48 with 72k miles I am going with the Melling M55 Standard Oil Pump. Aside from the "religious" issues, as it were, any reason why this is a bad idea??
With my bosses 30 years of oil system development and a great working relationship with OEM's in Detroit, I can tell you that no it is not a bad idea.
Note we have NHRA Super Stockers running SBC to 9000 rpm with 3 qts of oil and a std volume pump.
I did a high volume melling with my 383 conversion... consistently puts out 60 to 80 lbs of pressure...vs 20 to 45ish with the stock... must be good.
Some time ago a got the opportunity to drive a 2004 Porsche 911 and the one thing that impressed me the most was oil pressure, it remained very stable at 90psi at everymoment in every condition.
That’s the beauty of a dry sump oil pump. You can set the oil pressure and it will never vary more than a few pounds throughout the entire RPM range! It has its place right on the side of my aluminum race engine but for your street car with a stock engine I would run the standard pump. Road Race guys love high volume in the outlaw classes with the idea that more oil = more cooling from it; but that is debatable. I think that most of the hp/hv arguments stem from the "hey if it works on this race engine it has to work even better on my street engine right?" WRONG! Just my thoughts and slight rant.
I am building a 383 For my car. Comp Cams Retro 288 Hydraulic roller cam. Now I am worrying about the High volumn vs. High pressure debate. Blowing a lifter is BAD NEWS! So is pumping all your oil into the valve covers. Good post. I will keep my open!
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I run oil restrictors in the rear galleys and they limit the oil to upper valve train and keep more down towards the center of the motor, cam, lifters etc. seems to worlk pretty good for me, my solid roller lifters looked brand new after 10,000 miles
If you take the oil pump appart, you well see wear marks between the teeth. It may not seem like much, but the wear marks are there, hence purchasing a new pump, standard pump, makes a lot of sense.
Now, regarding the HV/HP pumps. If you're running a roller cam, especially a solid roller, it is imperative the lifters get lubrication, lots of lubrication and a HV pump will ensure the lifters will get lubricated.
If I were the poster of this thread, I would not hesitate to get a new pump, a standard pump. Using the old pump, the oil pressure will be there at cruising speeds, but at idle, the pressure will drop significantly due to the wear on the gears.
Something else...a new pump's gears should be packed with vaseline
I would put a stock pump back on it but not a HV. HV were intended for engines that had loose bearing clearances or run at very high rpms for extended period of time. I don't see either of these being your case. Along with that an HV pump takes more HP from the engine over stock to turn.
Chris Straub
Stef's Performance Products
Chris sums it up pretty good.... In this case high performance/high volume is not the way to go. If your concerned replace it with an OEM Oil pump.
I have always replaced with high volume, not high pressure, and have never had a problem. But I would at least replace with an OEM pump while I had the opportunity. Just my 2 cents.
Bernie
