Brake Fluid Leak
Old Feb 28, 2006 | 03:34 PM
ESU's Avatar
ESU
Default Brake Fluid Leak
I replaced the master cylinder and all 4 calipers along with some of the lines about a yr ago. Since then I'm losing brake fluid. Not a lot, just a little. Enough that it warrants being checked periodically. I dont drive the car much either. Anway I cant find a puddle or wet spot anywhere. Where is it going? Can the m/c be bad and leaking internally ? Brakes work fine. pulls a little to the right but I figure a re-bleed should take care of that. Car is a 79 w/ p/b. As always, suggestions appreciated.
Thx, ESU in NY
Old Feb 28, 2006 | 04:50 PM
MAZ73's Avatar
MAZ73
If you used rebuilt calipers there is a possibility of the seals leaking. You may find your brake fluid once you remove a caliper or two. Had similar problems earlier this year, found the fluid there, replaced all 4 calipers with no problems since.
Old Feb 28, 2006 | 05:26 PM
superdad60's Avatar
superdad60
Got stock rims?
Look in the back sides for tiny pools
Old Feb 28, 2006 | 05:42 PM
BB68Vett's Avatar
BB68Vett
If you have power brakes it could be leaking around the shaft seal and into the power brake booster.
Old Feb 28, 2006 | 05:44 PM
copter's Avatar
copter
Your brake fluid can leak into your booster.Happened to me.Yours might be going bad.Mine did.
Old Feb 28, 2006 | 05:59 PM
ESU's Avatar
ESU
Calipers are rebuilt stainless sleeved, will have to take a closer look at them. How can I tell if the m/c is leaking into the booster?
Old Feb 28, 2006 | 06:23 PM
copter's Avatar
copter
I wish I could tell you but I had to take mine into the shop.That kind of work is not my fortay,but thats what happened.The shop also told me that it could have failed the oppsite way and then your brakes will lock up.If nobady responds soon I Will find out tomorrow for ya.How is your pedal pressure and does your brake light come on?.I'm thinking not and you are in the first stage of the failure.No telling how long it will take.
Old Feb 28, 2006 | 07:43 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
just roll it in flour and look for the wet spot....
"How can I tell if the m/c is leaking into the booster" pull the vacuum line off of it and see if any brake fluid is present, i would think it would be present in the vacuum tubes going to the intake
Old Feb 28, 2006 | 07:53 PM
Hwy St*r's Avatar
Hwy St*r
You said car pulls to the right, check the left front caliper. I had replaced my calipers and had also had a small leak that I couldn't find accompanied by pulling to the left. It turned out to be the right front rebuilt caliper was bad. replaced that and all is now well, at least with the brakes.......
-Pete. KEEP DRIVING!!!
Old Feb 28, 2006 | 08:59 PM
ESU's Avatar
ESU
I'll take a look but might have to wait till the weather warms up a tad. The brakes overall feel fine, just that little pull, not spongy at all.
Old Feb 28, 2006 | 09:00 PM
ESU's Avatar
ESU
"Just roll it in flour",,,, wasnt that the advice for spending a night with a fat chick back in college days?
ESU
Old Feb 28, 2006 | 09:01 PM
ESU's Avatar
ESU
No fluid in the vac line.
Old Feb 28, 2006 | 09:38 PM
bobs77vet's Avatar
bobs77vet
ESU
after all a wet spot is a wet spot....
To Brake Fluid Leak
