Passing gear solenoid for TH400
Re: Passing gear solenoid for TH400 (LAWTON54)
I think that the switch in the trans and the other switch on the pedal under the dash or both still serviced by GM. Thad
Cruise-In III Veteran
Need information where to find a passing gear solenoid for a TH400.
Thanks in advance.
Thanks in advance.
Cruise-In VI Veteran
Cruise-In VII Veteran
If you can find the part number you should be able to get it from any Chevy parts department.
