Got ahold of Edelbrock..... they recommeded the most expensive springs they have (well just about) . Is there a way to determine what I need based on lift so I can get some other brand?
Maybe there is a reason for the springs that are "the most expensive". Don't cheese out on valve springs when you have a lot more $$$ below them!!!
Hyd flat with the OEM 3/8" heavy valves I would run around 120# on the seat and 320# Open. I would get matching retainers and machined valve locks for the application.
A single spring with a damper is what I would recommend. Beehive is not worth it especially with the heavy valves in OEM heads.
what you have to know...what is the spring pressure at the seat at the installed height, then buy springs that have identical seat pressure...contact the cam mfg and find out what spring pressure is required for the cam.
That means that when the retainer and keepers are installed on the valve that distance between the underside of the retainer on the first step (the largest OD) and the spring pocket is 1.880". At this installed height the spring should have 100# of pressure.
IMO, not enough seat pressure for that cam.
Issue here though is not the spring, it is the fitment of the spring to the OEM retainers. Ask E-brock tech if you can use those springs with OEM GM retainers.
The springs are there now were made by PBM racing and rated at .0600 lift...which they said were good enough for my cam....I'm being told they're not.... and now the new machine shop says that my Comp Cams roller tip rocker is actually hitting the spring. Looks like everyhting has to be repalced. I've had these heads done 3 times now. I could have aluminum for what is invested in these..... I'm tired and disgusted of the whole thing.....but want to do it right this time.
The cam, I assume is Edelbrock? If so, then look for springs that are 100 # at the seat installed. If Edelbrock says that's the spring for their cam, don't argue.
Regarding the rockers hitting the retainer, could be a number of things..Wrong installed height, rocker ratio more than 1.7.
If thats a PBM 3500 spring then that spring must be used with aftermarket retainers. The OEM retainer step will not locate the spring and will allow it to move.
Now because the retainer step does not fit the spring this allows the spring to move when running. Most rockers only clear 1.625" springs so with a your spring diameter of 1.550", the spring doesn't have to move much before it hits the rocker.
Don't quite know where Belleville,IL is but I know of a guy in Glasgow, KY that is one of the best around when it comes to BBC. If you want his number let me know.
Going to try new retainers as suggested. The rockers were hitting the springs. I'm guess the movement caused the pushrod to bind and fail..only took five miles
If so , you might want to think about using Clay Smiths dual interference fit springs set at 1.900 . Seat pressure of around 120 after the the springs take their normal set from run in and around 290-300 open at " those " lifts will provide adequate control and long life .
Alot of the springs out there are nearly on/off types like the single Z28 type springs . I like the types that are more progressive in design and they are about a must for the hi intensity nonsymmerical lobe being used these days .
Isky has springs galore if you cannot allow yourself to run the above or are not using PC seals . Some of the best around .
Mountain,
I can't tell if the valve guide boss has been cut for the PC seals but if I had to guess I would say they haven't. I agree a good Viton posi seal is great for oil control and longevity.
