Im getting ready to replace the engine in my 81 and are planning on converting it over to TPI. i have the basics, TPI unit, custom harness, computer..still need all the sensors, distributor, some fuel line connections.
I would like to get it running on its own power asap so i can move on to other things. One option ive considered is i could put carb back on it for time being would be easier then the things i would need to do to get the TPI working, then worry about converting it to TPI once its up and going, and closer to being completed.
Comments? suggestions.....guess im asking which way would you suggest
Any particular reason TPI? Why not move up to LS1? There are a lot of guys here on the forum that have done the LS1 conversion. Either way, I'm sure a bunch of guys will respond soon. Good luck.
