How do I test a Wiper Motor
Old Mar 1, 2006 | 09:14 PM
77 corVette's Avatar
77 corVette
Default How do I test a Wiper Motor
I have a 77 wiper motor that I want to test before I install it and need to know how to test it. Which terminal do I need to connect to a hot in order to make the motor operate and do I need to connect anything to the other two terminals. I have a light blue wire, a yellow wire and a black wire on a 3 prong connector and a black wire, ground wire on a separate connector.
Thanks, Rob
Old Mar 1, 2006 | 09:37 PM
myoriginal77's Avatar
myoriginal77
Can you just unplug the currrent one and plug in the test one. Make sure you have a good ground on the motor, without this they can act wierd.
Frank
Old Mar 2, 2006 | 03:06 PM
77 corVette
Default Bench Test
Frank,
Thanks for the reply, but my Vette is in for paint work, so I must bench test it the wiper motor. Suggestions appreciated.
Thanks,
Rob
Old Mar 2, 2006 | 03:21 PM
myoriginal77
I won't be home till later but I can check out the plug on mine and let you know which terminals are which if that helps.
Old Mar 2, 2006 | 07:19 PM
77 corVette
Default Wiper Motor bench test
Thanks! All assistance is appreciated.
Old Mar 3, 2006 | 05:58 AM
kb2fzq's Avatar
kb2fzq
On my 76, I taped the yellow wire to power my electric carb choke..I think it was the middle wire...the other 2, one goes to switch, one goes to washer...to take motor to ground...
To How do I test a Wiper Motor
