Angle plug v. Straight Plug
Old Mar 2, 2006 | 03:55 PM
dgruenke's Avatar
dgruenke
Default Angle plug v. Straight Plug
Is there any performance difference between an angle spark plug head and a straight spark plug head?
How do you decide which type to use?
Thanks everyone.
Old Mar 2, 2006 | 05:11 PM
Hauq`'s Avatar
Hauq`
Yes; heads with angled plugs have smaller combustion chambers and therefore higher compression. This is not a rule, but a generality. Heads with straight spark plugs are usually round the 76 cc area for SBC.
Old Mar 2, 2006 | 06:31 PM
dgruenke's Avatar
dgruenke
But a lot of the heads that I looked at give you the option to pick straight or angled and both have options have the same combustion chamber. How is this?
Old Mar 2, 2006 | 07:20 PM
Simmo's Avatar
Simmo
The angle plug head was originally introduced by GM for more power for motors with a domed piston. The bigger the dome the better the advantage, no dome no advantage.
Old Mar 2, 2006 | 07:46 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I ran Chevy angle plug heads on my 11:1 CR 350/350 and they seemed to offer a lot more power than the stock 2.02's. I ran the stock cam and a Torker intake with a 600 Holley double pumper. The long block, heads, cam, lifters, valves, and springs were all bought new from Chevy.
Old Mar 3, 2006 | 06:34 AM
enkeivette's Avatar
enkeivette
I have them, Dave at AFR told me that they tend to make slightly more hp.
Old Mar 3, 2006 | 08:45 AM
1971corvette's Avatar
1971corvette
I remember reading a long time ago they make about 5 - 10 more horsepower,this was on the old iron heads.
thinking about using angled plug heads,make sure the plugs will clear the exhaust or headers.
I am using dynomax full length under the car headers
part #289-86008 and have no problems with clearence on plugs,steering box ,and for $209.99 am very pleased with them.
I hope this helps you.
To Angle plug v. Straight Plug
