The wheel-base of the C-5 was streched to accomodate the new drivetrain 11 inches. Do that to your Vette and your half way there! All kidding aside, it would require massive man-hours and buckets of dead Presidents to accomplish. (Doesn't mean I wouldn't do it)
Also, C5 has a transaxle. There is no room for that in the C3. Basically, the transmission would be between the seats instead of under the dash. Major body mods would be involved.
With a C5 body. The C3 has a nearly 50/50 weight distribution, too (with a small block). Who knows where the weight would end up if you started down that path? I think it would tend to go rearwards, since the C3 was at nearly 50/50 with the transmission up front.
I'm asking about the track width, compared to a c3???
We were discussing all the issues involved - like the massive amount of work that it would take to clearance the body where the transmission would sit.
Saw the pics on the 69 (my favorite corvette) I hated the flares. They took away from the appearance of the car to me.
Dont like the way the front looks either. Im assuming they had to modify the body to accomadate the wider chassis.
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
We built a ton of parts for a '67 body that was put on a tube chassis that used all C-4 suspension parts. It was a sweet ride with a BBC and Richmond 6 speed. I think it sold for $120K. The guys are located in Lakewood, NJ.
what makes you say that? the C5 has a weight balance of 50/50
i am not shure of the numbers on how much the engine weighs but the trans/differential is shure heavy,.but i am shure some engineer who gets payed way more than me could tell you.
now all that considered, moving the weight from the front center of a c3 to the rear.
consider this my frend, there is 30 years of technology that comes in to play.
I know lets re invent the wheel
SORRY!!!
Reason: mistakes
