Wiped Cam Question
Old Mar 3, 2006 | 07:51 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Wiped Cam Question
What does a "wiped" cam look like? I'm guessing instead of a shiney lobe surface I'll see one that is rough?
Old Mar 3, 2006 | 08:31 AM
1971corvette's Avatar
1971corvette
It will look like a groung down piece of junk.do you think you have a wiped cam ??watch the lifters to see if they all move about the same as the motor is turned over.
hope this helps
Old Mar 3, 2006 | 11:19 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
well instead of having an egg shaped lobe it will look more like a circle
Old Mar 3, 2006 | 11:21 AM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
EXACTLY
Old Mar 3, 2006 | 12:12 PM
SteveG75's Avatar
SteveG75
Pull the lifter. It will be slightly concave instead of convex.
To Wiped Cam Question
