the fronts also have the french lock for the upepr caliper bracket bolt, the rears are the anchor plates for the parking brake spring anchors. The front can be removed with no ill effect, the rear must be cut to retain the center section for the parking brake.
Unless you do away with the parking brake as well. No parking brake on mine, if I need one, I hit the line lock!
