Exhaust "flapper" valve.
Old Mar 4, 2006 | 01:39 PM
hensen1954's Avatar
hensen1954
Default Exhaust "flapper" valve.
Think in the USA you call them exhaust recirculation valve / plate whatever.
Anyway, on my 81, with the engine off will the valve sit open or shut ??
Cheers,
Hugo.
Old Mar 4, 2006 | 04:39 PM
ESC3's Avatar
ESC3
If it's the one on the exhaust manifold your talking about it called a heat riser here and I believe it sits closed.Hope that helps.
Old Mar 4, 2006 | 05:12 PM
694speed350's Avatar
694speed350
Depends on the heat of the exhaust. they are controlled by a bi-metal spring when the exhaust gets warm enough they open. when it gets cool enough it will close
Old Mar 4, 2006 | 06:46 PM
hensen1954's Avatar
hensen1954
mine has a vacuum pipe and a diaphram - suck to activate - just like a girl I know..........
To Exhaust "flapper" valve.
