Tune Up Assistance NEEDED!!!!
Old Mar 4, 2006 | 05:48 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Tune Up Assistance NEEDED!!!!
Ok...here's the deal....I have a 75 Convertible with an HEI ignition (Mallory) and a new Holley 650 Street Avenger and recently I have replaced all the spark plugs.
I have a mild cam so I initially set the timing to 6 degrees BTC and the car pings on acceleration...so that tells me I'm advanced too much... I reset the timing to 4 degrees...still has the pinging (not as bad) and I cannot set the RPMs...it idles (in park) at 700 then it jumps to 1100 then it drops to 500...all in about 1 minute. When I "goose" the engine a couple of times, the RPM stay at 1000. I check the timing....and it now show 12 degrees.... WHAT THE HECK IS GOING ON????? A vacuum leak? I checked all the hoses for leaks (all seem to be ok)....my lights work perfectly....The only thing I am going to replace is the console Heater/AC control...the left wheel won't go all the way to the top....I understand there are some tiny vacuum lines in the control unit...do you think that the heater/AC controls not working may be affecting the engines timing??? Any help will be GREATLY apprectiated!!!!...I am at witts end!!!! I have spent the better part of today trying to set the timing......WITHOUT ANY LUCK!!! Decided to check with you guys....
I know, I know...."Just because I'm cussing, doesn't mean I'm not having fun!"
Old Mar 4, 2006 | 08:00 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
most of us are running much higher timing numbers then those.....what kind of vacuum are you getting and what vacuum cannister are you running and is it ported or unported? i don't think you should be getting pinging....what octane are you running and what is your CR?
edit: you know is there any evidence of your harmonic balancer having slipped????
Old Mar 4, 2006 | 08:28 PM
TexSon's Avatar
TexSon
You may want to check the vacuum advance. It might be or is going bad. Or it might just be the vacuum advance line.
Old Mar 4, 2006 | 08:36 PM
bobs77vet's Avatar
bobs77vet
the vacuum controls for the heater have nothing to do with this ....you may have a vacuum cannister that is not working correctly. is this an auto or a 4spd? i think you have a vacuum cannister that is hunting and changing the timing on you .....i also think your harmonic balance might have slipped...i can't think of any reason for you to be getting ping unless you have a really CR at the timing setting you "think" you are getting
edit: you know not for nothing here but ....my fan clutch crapped out at exactly the time i was setting my timing and i mistakenly thought that i had detonation....you may want to look at the fan clutch
Old Mar 4, 2006 | 10:30 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Default Lean Idle Condition
Sounds like a lean idle condition. Make sure the mixture screws are set according to the manual and go from there. Also, you need to find a base line for your timimg. Set your timing with the vacuum advance plugged. Try 8 degrees at 700 RPM and then use full manifold vacuum. Your idle speed will go up, just adjust down the idle. Start with heavy mechanical advance springs so the advance comes in slowly and go from there. Good luck, you will get there.
Old Mar 4, 2006 | 10:50 PM
supercalvin's Avatar
supercalvin
I have 20* at idle and 36* with full centrifical advance
Assuming the balance and pointer are accurate.
Assuming the cheap Harbor freight Advance timing light is close.
77L82
Stongly recommend Lars Timing paper
Old Mar 4, 2006 | 10:56 PM
vetteguy75's Avatar
vetteguy75
I just had a new harmonic balancer put in at the local Chevy dealership about 1 month ago. I may have them look at it to make sure it hasn't slipped. What is a "CR"?
Old Mar 4, 2006 | 10:58 PM
vetteguy75's Avatar
vetteguy75
Thanks....I will check that in the morning. I know whenever I use the timing light, I plug the advance line to the carb and the advance port from the distributor.
Old Mar 4, 2006 | 10:59 PM
vetteguy75's Avatar
vetteguy75
I will also check the lean idle condition in the morning....by the way...what do you mean by "Try 8 degrees at 700 RPM and then use full manifold vacuum." I understand the 8 degrees and the 700 RPM but what do you mean by use full manifold vacuum?
Old Mar 5, 2006 | 12:17 AM
isosceles's Avatar
isosceles
check the mechanical advance as well. Make sure it snaps back. It might be slow to return.
Old Mar 5, 2006 | 12:59 AM
Jeff_Keryk's Avatar
Jeff_Keryk
Carbs usually have 2 vacuum ports; you will use 1 for the vacuum advance hose. Earlier engines used full manifold vacuum (ported below the throttle plates) while smog engines used ported vacuum. Ported vacuum is low (or non-existant) at idle because the port is above the throttle blades. When the throttle blades open slightly, atmospheric pressure forces air through the throttle body (ported vacuum) which activates vacuum advance. Smog engines were designed to run hot. Full manifold vacuum will help with idle to off-idle transition and at cruise. Chevys like a lot of timing, just make sure your carb is not tuned too lean. There are many opinions on timing, it is best to experiment and see what your engine likes.
Old Mar 5, 2006 | 08:34 AM
bobs77vet's Avatar
bobs77vet
CR is compression ratio.....my post should have said unless "you have a really high compression Ratio engine".
you should be able to get this right, something is askew but we can help you figure it out.
To Tune Up Assistance NEEDED!!!!
