Is This Intake Dual Plane?
Old Mar 4, 2006 | 09:29 PM
LittleJake's Avatar
LittleJake
Default Is This Intake Dual Plane?
Is this intake dual plane? Its the factory aluminum 70 LT-1 intake GM#3972110. I looks like it is from the pics but im not sure and I dont know if I really know what to look for anyway.
Thanks for any help!
Old Mar 4, 2006 | 09:31 PM
rcread's Avatar
rcread
Yes.
Old Mar 4, 2006 | 09:32 PM
LittleJake's Avatar
LittleJake
Thanks! Sorry for the newb question.
Old Mar 4, 2006 | 09:36 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Single plane would have one large plenum that the carb mounted on & the runners would look like a big X, when viewed from above. You could look down all 8 intake runners.
Old Mar 4, 2006 | 09:40 PM
chewy's Avatar
chewy
Excellent manifold for anything but very serious race use.
Old Mar 4, 2006 | 10:44 PM
Bee Jay's Avatar
Bee Jay
I have that manifold. It's an LT-1/Z28 manifold. Mine is modified to take a Quadrajet, and port matched to the Felpro 1506, just like my Airflow Research 195s. Works great. I take my engine to 6500 rpm all the time. I would like to try the Performer RPM, but the don't make it for my Quadrajet.
Bee Jay
Old Mar 4, 2006 | 11:19 PM
shafrs3's Avatar
shafrs3
Single plane...
Old Mar 5, 2006 | 12:46 PM
Ironcross's Avatar
Ironcross
Terrific manifold. Basically the same manifold used on all the factory Z28 Camaros and as good as it gets.
Old Mar 5, 2006 | 02:05 PM
LittleJake's Avatar
LittleJake
Well I had hoped to pick the pictured intake up on ebay but the price is already up to $300.00 with a lot of time to go. More than I was looking to spend on an intake at this time. Guess I will keep looking.
Thanks guys for all the help! Now I know what to look for.
Old Mar 5, 2006 | 02:10 PM
rcread's Avatar
rcread
Yeah, these usually go for around $350, from what I've seen. You might consider an Edelbrock Performer for far less.
Old Mar 5, 2006 | 02:58 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Hey, we like those easy questions! Larry
Old Mar 5, 2006 | 04:25 PM
Ganey's Avatar
Ganey
LittleJake
If the green conv. in your pic. is your car the 2101 Performer will fit much better or maybe the Edelbrock EPS. You need about 3/4" clearance over the Holley vent tubes.
Old Mar 5, 2006 | 04:55 PM
rcread's Avatar
rcread
Originally Posted by Ganey
LittleJake
Yep, that's what I have in my '71 Roadster. It's a good, solid performing intake and an easy swap.
Old Mar 5, 2006 | 06:16 PM
LittleJake's Avatar
LittleJake
Yes, thats my car and I will check those two options out.
Thanks again!
Old Mar 6, 2006 | 08:33 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Default are you sure??
That intake has an oil filler tube hole, with they stopped after 68. either its not a 70, or someone openeed up the hole. If you dont want it ill take it for my 68
little detail
tim
Old Mar 6, 2006 | 09:03 AM
Ed Blue 03's Avatar
Ed Blue 03
These manifolds are hard to come by at a reasonable price, they are good manifolds and are used for LT-1 restorations. If you're set on buying one try Camaro forums also.
To Is This Intake Dual Plane?
