How do you fill your Muncie?
Old Mar 5, 2006 | 11:52 AM
theandies's Avatar
theandies
Default How do you fill your Muncie?
I am just about to put my car back down on the ground after my transmission work. I tried to fill the trans yesterday with gear lube but that stuff just doesn't flow like regular oil so I am wondering how you guys fill your trans while it is in the car? I am thinking about going and getting some sort of pump but I wanted to get your techniques.
Old Mar 5, 2006 | 11:59 AM
StickShiftCorvette's Avatar
StickShiftCorvette
They sell hand operated lube pumps that allow you to easily fill them. They look like a snow cone syrup pump.
Old Mar 5, 2006 | 12:03 PM
GDaina's Avatar
GDaina
I just put the snout in the tranny hole, and squeeze the plastic bottle...works great
Old Mar 5, 2006 | 02:51 PM
theandies's Avatar
theandies
You must have a lot more room than I do or you have some special trick for placement of the bottle. I could get some of it in using this method but I'd still be under the car squeezing.
I went to our local parts house and picked up a hand pump. It looks like bicycle pump for oil. Best part is that I can use it to suck the old fluid out when the time comes for that. After getting this it took less that 5 minutes.
Thanks everyone!!
Old Mar 5, 2006 | 07:09 PM
vabeachvette's Avatar
vabeachvette
I got a piece of small hose that it pushed through the cap snout and squeeze it on in, works great.
[IMG][/IMG]
Old Mar 5, 2006 | 07:14 PM
w1ctc's Avatar
w1ctc
Go to a boat store and check out the gizmos for filling a stern i/o drive.
Old Mar 5, 2006 | 07:54 PM
waterplay's Avatar
waterplay
That what I use! Works great and is very easy.
Old Mar 5, 2006 | 08:00 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
with sawdust, outmeal, and grits
Old Mar 5, 2006 | 08:24 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Man, you don't sell cars, do you?
I used Mobil 1 and a clear hose on the end of the squeeze bottle.
Old Mar 5, 2006 | 09:53 PM
68/70Vette's Avatar
68/70Vette
Although filling it is not easy, removing old fluid is much more difficult. I tried sticking down a plastic tube attached to a vacuum pump and I couldn't get the plastic tube down into the interior portion of the transmission to get out the oil. The next time I take a transmission off to a rebuild shop, I'm going to ask them to put a drain plug in it even thought this is not a NCRS rework activity.
(PS I ultimately removed the old transmission fluid by removing the transmission, removing the fill plug, turning the transmission on its side and let all the old oil drain out.)
Old Mar 6, 2006 | 08:40 AM
BB68Vett's Avatar
BB68Vett
I used a long piece of hose, put one end in the fill hole and routed the other end up through the engine compartment. I was underneath the car and had a friend at the other end of the hose. We stuck a funnel on the end of the hose and poured the gear oil in until it filled up. This requires two people but it worked well for me. I could not get the gear oil bottle at the correct angle to squeeze into the fill hole.
Old Mar 6, 2006 | 09:14 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I use a old soda fire extinguisher put a tire valve near the top dump in my gear oil...screw the regulator lid back on pressurize to about 25lbs..put the hose in the tranny squeeze the trigger....done! works great on rear ends too
Old Mar 6, 2006 | 12:14 PM
Hammerhead Fred's Avatar
Hammerhead Fred
[QUOTE=vabeachvette]I got a piece of small hose that it pushed through the cap snout and squeeze it on in, works great.
Old Mar 6, 2006 | 01:38 PM
matthud's Avatar
matthud
How much oil does a Muncie hold?
Old Mar 6, 2006 | 06:24 PM
ZO SIC's Avatar
ZO SIC
Mine took 1.5-1.75 quarts...
And what year(s) did they NOT come with a drainplug?
My '72 has a drain plug, but I am not sure if this is the original/correct trans or not.
Old Mar 6, 2006 | 06:33 PM
GTR1999's Avatar
GTR1999
I think the drain plugs were added about 71 or 72, when they went to the fine spline maybe?
On the older ones I tap the bottom for 1/4 npt pipe plug and then use a bushing and 1/8 plug. You can drain it easier and the bushing prevents wearing out the tapped hole in the aluminum.
Old Mar 6, 2006 | 10:35 PM
PRNDL's Avatar
PRNDL
from an article somewhere: " For the 1970 model year, there were two major changes to the Muncie four-speed. In previous years only the M22 transmission had a drain plug, however, beginning in 1970 all Muncie four-speeds now had a drain plug."
Don't know what the 2nd major change was!
Old Mar 6, 2006 | 10:52 PM
lucky76's Avatar
lucky76
Heat it somehow (microwave, hair dryer, or set in hot water) so it will pore better. A rubber hose and a funnell from the engine compartment worked best for me. How do you tell when it's full? When it runs out the filler hole it's full.
Old Mar 6, 2006 | 11:19 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...been into boats for about as long as I've been into Corvettes. Have had this Mercury Marine boat lower unit pump since 1988. Screws into virtually all oil plastic quart bottles. I use it for tranny fluids, rear end fluids and stern drives. Best $9 I ever spent.
To How do you fill your Muncie?
