I am starting to think.........
Old Mar 5, 2006 | 03:40 PM
hensen1954's Avatar
hensen1954
Default I am starting to think.........
Was blasting along today in my BM, thinking about worn carbs, having to call in Lars etc.........and suddenly the dark side took over and my resistance to fuel injection ( when rebuilding my C3 engine ) seemed to fade away !!
OK, give me reasons for and against please - money is not that important - just want it to run right - everytime.
Old Mar 5, 2006 | 06:14 PM
hensen1954's Avatar
hensen1954
No ideas anyone ??
Old Mar 5, 2006 | 06:47 PM
72LS1Vette's Avatar
72LS1Vette
Pros:
Smooth running.
Better fuel economy.
Look s good.
Tuning via laptop.
Cons:
Expensive.
Additional wiring.
More difficult to troubleshoot problems.
Probably requires new fuel lines.
If money isn't an issue, you want a good looking and good running system, and you're not concerned about originality, I'd say go for it!
Rick B.
Old Mar 5, 2006 | 07:35 PM
JPhil's Avatar
JPhil
What he said.
Old Mar 5, 2006 | 07:46 PM
chris75stingray's Avatar
chris75stingray
cons: COMPUTER
Old Mar 5, 2006 | 07:58 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by chris75stingray
cons: COMPUTER
That remark doesn't make sense! Computer = consistent performance, improved gas mileage and much less tendency to run poorly at different (high or low) operating temps.
You realize I hope, that it is only computers that have kept the NEW car hot rod dream alive! It's because you can almost breathe the air coming out the tailpipe on a well-tuned, computerized EFI engine with a CAT.
Old Mar 5, 2006 | 08:01 PM
JPhil's Avatar
JPhil
Hmmm...another con thought: Fuel system modifications.
Ain't gonna stop me, though, when the time (read: $$$$) comes my way.
Old Mar 5, 2006 | 08:08 PM
C371's Avatar
C371
Default Best Upgrade So Far
I installed a Holley CMD950.
It is great!
Starts everytime hot or cold.
Adjust for emission check
Adjust back to perfomance tune
It does take a few hours of effort to get it dialed in.
Wideband O2 helps!
Old Mar 5, 2006 | 08:14 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Cons: More difficult to troubleshoot problems.
Absolutly not true, as a matter of fact it is alot easier
cons: COMPUTER
The opposite is true. I have to strongly agree with SanDiegoPaul If you are computer savey enough to operate your home PC and have the smarts to work on a carb, FI should be a breeze.
Bullshark
Old Mar 6, 2006 | 12:39 PM
hensen1954's Avatar
hensen1954
How does the computer do its stuff ??
On my BM there is a flywheel sensor ( actually 2 ) to give TDC etc, does a Vette system have the same ??
How much difficult wiring - rather than a power wire or two ??
What tuning problems ??
Am coming to Florida in a few weeks time and could hide stuff in my suitcase for the return journey - so need to sort this out kinda quick .
At the moment I ahve bought everything apart from ther carb for a traditional set up.
Although its not the right subject here - has anyone thoughts or experience of which are the beat ally heads and intake to go obn a raodgoing Ford 302 ??
Got more than one project to get sorted.
Old Mar 6, 2006 | 06:28 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
The Commander 950 (as the poster above stated) is pretty foolproof. I would recommend a wideband 02 also and you will need a EFI throttle body and a new pump/fuel lines. Some on this forum have converted to the GM TPI setup. Lots of info on that.
Do you live outside the US? I am assuming that is why you want to get this stuff while you are here. Also, just out of curiosity, what is a BM?
Old Mar 6, 2006 | 07:08 PM
enkeivette's Avatar
enkeivette
Yeah but I can see where he is going, little electronic parts (i.e. chips, resistors, sensors, capacitors etc.) can take a crap on you. And without a computer to plug into the car to generate a code you're SOL. Even with, it just makes the puzzle more complex. But granted, a FI vehicle with no electronic problems is optimal.
Old Mar 6, 2006 | 07:36 PM
Nemesis_152's Avatar
Nemesis_152
the electrical parts of today are far more reliable than things like carburetor internals. solid state electronics are great.
Old Mar 7, 2006 | 08:03 AM
UKPaul's Avatar
UKPaul
Hensen,
Remember Renault 30's? For my sins I had one of those ill handling, ugly POS and it was fitted with a carb. A visit to the breakers got me the parts to convert to FI & the difference was unbelievable. Easy starting & better economy were side issues - the increase in power was phenominal, it really felt alive with great throttle response & ran much smoother. The only downside was the insurance company increasing premiums due to it. If I had the cash (& I'd done everything else - heads, smart struts, paintjob, steeroids, etc, etc, etc) I'd have no hesitation in fitting FI to the Vette. I can't see the problem with new-fangled, rinky dinky technology... afterall, the V8 was once new technology
Old Mar 7, 2006 | 09:51 AM
Paul L's Avatar
Paul L
I believe you will have to convert to an electric fuel pump as well to get the correct pressure at the fuel rails.
Old Mar 7, 2006 | 12:28 PM
hensen1954's Avatar
hensen1954
Thanks everyone- would be handy to pick up everything in Florida in one go. Will be there for 3 weeks, so not impossible.
Re question - BM is short for BMW - quite a popular car...........
Having said that its raining here in West Wales and in the next hour or so I have to move (not very far, thank God ) my open 1934 Wolseley.
Back to C3, if I go TPI its gonna bugger up a procharger step later on.........
Old Mar 7, 2006 | 03:43 PM
bashcraft's Avatar
bashcraft
Oh, thanks for the clarification. I thought it had something to do with a bowel movement.
To I am starting to think.........
Old Mar 7, 2006 | 04:26 PM
stickboy's Avatar
stickboy
If you are doing batch fire a regular distributor gives the ECM all of the info it needs. However for sequential your need more info which can come from a crank sensor or other thing. I am using and Accel dual sync distributor with has to outputs, cam and crank.
as for pros and cons they were listed pretty well in Blair Winch Project's post.
Old Mar 7, 2006 | 04:31 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
if money is not an issue go for the EFI...i would
Old Mar 7, 2006 | 07:45 PM
shafrs3's Avatar
shafrs3
Holley's systems, as well as others, can be tuned for supercharging applications.
