71 brake booster
Old Mar 5, 2006 | 07:32 PM
vabchmopar's Avatar
vabchmopar
4th Gear
Default 71 brake booster
I am having problems getting the booster out of the car. I have removed the steering column and 3 of the 4 bolts that hold the booster to the firewall but I can not get the drivers side top nut off. Do I have to remove the pedal assembly, if so I don't see how that assembly comes out?
Old Mar 5, 2006 | 09:15 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Should just be four nuts on the inside near the steering column. I took it out without taking the column out. The pedal assembly can stay.
Old Mar 5, 2006 | 09:19 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
you have to break your right arm in two places and your left in three, then you can get in there...
seriously, it's a bitch, but you can get to it..
a swivel socket, a twelve pack, and some patience...
Old Mar 6, 2006 | 12:35 AM
XLAR8R's Avatar
XLAR8R
i bought a 3/8 ratchet with a swivel head when i did mine and that helped with a couple of em. i even did mine without taking out the seat or the column. didnt know my body would bend that way.
Old Mar 6, 2006 | 12:51 AM
Muddywaters's Avatar
Muddywaters
Use duct tape on the swivel to stiffen it up. Little bit easier to remove the seat... slowly but sure'ly...
Uncle Ralphy's Avatar
Uncle Ralphy
Use a 3/8 deep socket, a u-joint (taped a little so it won't flop around),a short extension and a long swivel head extension, in that order. It took me 2 months of procrastination before I worked up the courage to do this job and 5 or 6 minutes to take that upper left nut off when I finally got around to it.
You definitely don't have to do anything to the steering column. I did however take the brake light switch off. It took longer to get that back on than it took me to get that upper nut off.
Also, I had the seat out which helped a lot for moving around under there.
When I put the new one in, I left the upper left nut off. There was no way I could get it back on.
Old Mar 6, 2006 | 12:56 AM
Muddywaters
Uncle Ralphy... I stuffed my deep socket with paper (less the depth of the nut) I then put a little grease in the socket to hold the nut then turned the extension by hand untill it started...
Old Mar 6, 2006 | 04:47 PM
Dick72LT1's Avatar
Dick72LT1
I got the first nut with my 1/2" drive socket, went to the 3/8" for one or two then went to my 1/4" for the last nut. Seat out helps. I think the 1/4" drive is the way to go with extensions and u-joint.
To 71 brake booster
