I have a complete 454 I have been eyeing for my 79'.I don't want to hack the car up since it is all original,but I'd like more pwr than the stock motor can give me.So I am probably gonna put the stock motor in a corner and put in something else.I was going to do a stock appearing SB but the BB is just screaming in my ear.So aside from front springs what else is needed for a big block in 79'?And do I need to change the hood or is there an intake and air cleaner that will work under the stock hood?Thanks in advance.
You need BB accessory brackets, exh manifolds or headers. Some intakes fit, but they are pretty flat-also not sure about with a stock hood. Possibly bigger radiator.
IMHO you are better off with a better small-block. Put your original in a corner, buy a $100 core motor and build a monster.
Got all the pulley's and most of the brackets,so if it's a matter of a hood?
You have Corvette pulleys and brackets or passenger? There is a difference.
You don't have to hack the car to install a BB, but you will have to change at least some of your exhaust at a bare minimum. I think you need a taller hood, even to run a stock iron BB intake. I don't have anything against a BB, but they are heavier on the nose and if you already have a SB in there, there are some costs that you would not have to deal with if you stay with a SB. If you are bent on having one, it's not that big a deal to swap-just money for little stuff.
