NO2 Melting Cats
Old Mar 7, 2006 | 08:06 PM
enkeivette's Avatar
enkeivette
Default NO2 Melting Cats
Someone told me that burning nitrous will melt your catalytic coverters, if it is set up properly, is this true?
Old Mar 7, 2006 | 08:27 PM
Beater's Avatar
Beater
it is my understanding that runing lean melts cats. Nitrous does the opposite. Not that it is any good for them.
Old Mar 7, 2006 | 09:00 PM
enkeivette's Avatar
enkeivette
Mmm, a dry shot of nitrous would tend to lean things out. Nitrous adds air to the system not fuel, think chemical supercharger. But I'd go with a wet shot, nitrous jets matched by extra fuel jets. So it shouldn't be lean.
Old Mar 7, 2006 | 11:25 PM
Beater's Avatar
Beater
Most kits I've seen have a fuel line run with them. You can't burn the air with out the fuel.
Old Mar 8, 2006 | 12:38 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Oh yes you can, problem is it tends to put holes in the pistons.
Old Mar 8, 2006 | 01:52 PM
chris75stingray's Avatar
chris75stingray
running lean will make the engine run hotter, but running rich will cause the cats to melt
the nitrous alone will make it run lean, that is why you need more fuel to go with it.
Old Mar 8, 2006 | 02:06 PM
Solid LT1's Avatar
Solid LT1
Exhaust gas temps rise quite a bit with N2O and it wouldn't surprise me to see shorter convertor life when using it. If the system is set rich as it should be that will lower convertor life too.
Old Mar 8, 2006 | 02:12 PM
Nemesis_152's Avatar
Nemesis_152
just run no cats
Old Mar 8, 2006 | 02:45 PM
chris75stingray
Originally Posted by Nemesis_152
just run no cats
if your looking for better performance then cats aint helping at all
Old Mar 8, 2006 | 02:51 PM
enkeivette's Avatar
enkeivette
2500$ fine in CA if you fail a roadside visual. There's no way I'd smog my car as it is, and my cats aren't even legal because I have two 3" cats instead of just the one 2.5" cat. But they look good to cops. I'll eat the 10hp for some insurance.
...I think Norval even runs cats for the same reason.
Old Mar 8, 2006 | 06:10 PM
694speed350's Avatar
694speed350
Torque vette take them off and gut them they are still there but without the insides.
Old Mar 9, 2006 | 12:12 AM
enkeivette's Avatar
enkeivette
My car is loud enough already, they're high flow cats so it's really not a big deal. I don't want it any louder and I'd feel bad polluting a lot more for such little gain, the liberal college student in me is taking over here .
Click here to see Video
Old Mar 9, 2006 | 12:14 PM
Scooter70's Avatar
Scooter70
Why are you putting nitrogen dioxide in your car?
Old Mar 9, 2006 | 02:10 PM
25th silverbullet's Avatar
25th silverbullet
St. Jude Donor '05-'07
Old Mar 9, 2006 | 02:22 PM
norvalwilhelm's Avatar
norvalwilhelm
Same here. I don't want the immediate fine I would incure if I failed the visual inspection.
There is not problem running cats and nitrous. Exhuast temperature while under juice do not climb higher.
Nitrous itself has a cooling effect on the intake charge and the burnt gas is no hotter. Think of the short duration you are actually on the juice?? Compare it to a steady run down the highway?
No problem for the cats.
Old Mar 9, 2006 | 02:27 PM
norvalwilhelm
We should try to do out bit. Keep the car lean, run it hot enough and maybe we can cut down some polution.
I try at least.
Old Mar 10, 2006 | 04:01 AM
enkeivette's Avatar
enkeivette
I try at least.
To NO2 Melting Cats
