Speedo question
Old Mar 8, 2006 | 01:03 PM
HO-alts-Rick's Avatar
HO-alts-Rick
Default Speedo question
Can I use an older higher MPH speedo in my 1981? What changes have to be made? I hate the fact that mine has an 85mph speedo and want to replace it.
Old Mar 8, 2006 | 02:05 PM
icanfixitforyou's Avatar
icanfixitforyou
To the best of my knowledge, it is a straight swap, no modifications required. I would double check the location of the turn signal and parking brake indicator lamps etc.. just to be on the safe side. My .02 Good luck!
Old Mar 8, 2006 | 04:05 PM
palazzopl's Avatar
palazzopl
your 81 has a speed sensor in it that tells the tranny if it auto when to lock up the torque converter,,there is a shop that converts your speedo for $80 go to corvetteinstruments.com's
Old Mar 8, 2006 | 05:59 PM
HO-alts-Rick
Thanks just got off the phone and he was very helpfull.
Old Mar 9, 2006 | 11:00 PM
81cali's Avatar
81cali
been browsing the threads and came to this one, how do i remove the speed sensor and where is it located? first of all, can it be done?
Old Mar 10, 2006 | 12:25 AM
terry82's Avatar
terry82
http://www.redlineg.com/they have the speedo that you want
Old Mar 10, 2006 | 09:04 AM
palazzopl's Avatar
palazzopl
there is a plug in back of the speedometer .it has a small LED on it..I can't see any reason to un plug it.. you can also unplug it at the top of the computer..look at the manual
To Speedo question
