Aluminum pulley problems. Suggestions?
Old Mar 8, 2006 | 02:05 PM
Gordonm's Avatar
Gordonm
Default Aluminum pulley problems. Suggestions?
I got a set of aluminum pulleys and of course they don't line up like everything else on this freakin car. You go and try to upgrade and 4 other things don't line up or work out. The pump is an Aluminum Weiand pump. Why doesn't this stuff work the way it is supposed to. Everything is custom once you start changing things. Other than throwing the pulleys as far as I can what else to do with them.
Old Mar 8, 2006 | 02:14 PM
SIXFOOTER's Avatar
SIXFOOTER
Looks like you need to put a spacer behind the crank pulley. Don't know if there is a way to slide the wp pulley flange back on the wp shaft or not. It the distance from the block surface to the pulley flange the same on the weiand pump the same as a stock unit?
Old Mar 8, 2006 | 02:17 PM
rosslato's Avatar
rosslato
yep, spacers, thats what i had to do to mine but on the alternator and power steering pulleys
Old Mar 8, 2006 | 02:21 PM
Gordonm's Avatar
Gordonm
If I space out the crank pulley then I have to space out the PS and Alt. pulleys also. I thought of milling the back side of the WP pulley but it will get pretty thin by the time it will line up.
Old Mar 8, 2006 | 02:30 PM
rosslato's Avatar
rosslato
it's a pita but u gotta do what u gotta do, space away. u could always send the pulleys back, another pita. i've had to do this 3 different times, i screwed up and got the march under drive pulleys. 1st i had to change back my alt pulley due to dead batteries and then the crank pulley due to running hot.
Old Mar 8, 2006 | 02:32 PM
tshort's Avatar
tshort
CI 7-8 Veteran
I had the same problem and switched out to another water pump and the new pump lined up better.
Old Mar 8, 2006 | 02:42 PM
chris75stingray's Avatar
chris75stingray
couldn't you mill the water pump flange(where the pulley bolts to)? its like a 1/2 " thick isn't it
Old Mar 8, 2006 | 02:43 PM
Gordonm's Avatar
Gordonm
One other thought I just had. What is the difference between a WP pulley for a short WP vs a long WP pulley. If it were going to push the grooves back around .300 inches towards the engine it would work. Anybody know what the difference between the two is?
Unfortunatly I chucked the old WP so I can't measure the difference between the old iron WP and the new aluminum pump.
68/70Vette's Avatar
68/70Vette
Look at where the water pump mates to the block. In the photo it looks like the water pump casting it has a thick shim molded into the the castingpump. if you have to mill anything, perhaps you could mill the pump water tube stand off so that the pump became a shorter pump. (Although milling the pump standoff so that it became a shorter pump doesn't sound like a fun thing to do. And by the way have you compared the dimensions of the water pump flange/pulley distance to the block? Is it the same as the "short" SB water pump.) Good luck!! Looks nice though.
Old Mar 8, 2006 | 02:45 PM
Garrett1972's Avatar
Garrett1972
You might look at machining a little off of the water pump where it meets the block. Just enough to get the pully to line up, make sure there is enough space between the back of the pump and the timing cover.
Old Mar 8, 2006 | 03:10 PM
Gordonm's Avatar
Gordonm
I can't mill the pump as it will hit the timing cover. It only has a slight clearance as it sits now. I put the stock pulleys back on and it all lines up. I think these are going to go back. I did a bunch of measuring and these would not line up without considerable work. Oh well bad purchase. I'll try again
Old Mar 8, 2006 | 03:26 PM
vettfixr's Avatar
vettfixr
Gordon
If the pulleys are for a short water pump and not specifically a "corvette short water pump" they will probably be misaligned. The corvette pump is different from a regular short water pump. I don't have the exact specs at my fingertips but I believe the dimensions from the mounting flange to the pulley flange are different. Check with the pulley supplier to see if the pulleys are specific to corvette applications. Good luck.
Old Mar 8, 2006 | 03:32 PM
vettfixr's Avatar
vettfixr
Found it!
http://www.vetteweb.com/tech/0207vet_thebigchillb/
During the first two decades of the Chevrolet V-8, a great variety of water pump configurations were utilized. The one constant, at least through the 1968 model year, was the length of the leg, i.e. the distance the body of the pump stood away from the front of the block (this appears to hold true for '65-68 big-blocks as well as for all small-blocks). All the various and sundry water pumps were of a "short leg" design. Starting in 1969, with the sole exception of the Corvette, the pumps were changed to a "long leg" design--Corvettes used the short leg water pump through the end of 1970. The '71-82 (the latest for which we have reference data) Corvettes used a shorter long-leg pump than other small-blocks.
Old Mar 8, 2006 | 04:56 PM
Skid*MARK's Avatar
Skid*MARK
If all else fails you can take the back off the water pump and support the back of the shaft in a press and press the pulley mount flange onto the shaft further.
I have done this and it is the same as when you rebuild the pump and install a new bearing and seal kit.
Just get the amount that you need to go back and make sure that you have that much distance behind the pulley flange before you start.
Mark G
Old Mar 8, 2006 | 05:01 PM
jackson's Avatar
jackson
Exactly! Also ... look closely at that weiand pump's hub ... some have a setscrew in them ... my weiand P/N 8222 does.
Originally Posted by Skid*MARK
If all else fails you can take the back off the water pump and support the back of the shaft in a press and press the pulley mount flange onto the shaft further. I have done this and it is the same as when you rebuild the pump and install a new bearing and seal kit. Just get the amount that you need to go back and make sure that you have that much distance behind the pulley flange before you start. Mark G
Old Mar 8, 2006 | 06:39 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
switch to a short water pump.
Old Mar 8, 2006 | 07:29 PM
Gordonm's Avatar
Gordonm
It is a short water pump. I think these will go back. After much more measuring and checking I just don't think these are correct and I don't want belts flying off.
To Aluminum pulley problems. Suggestions?
Old Mar 8, 2006 | 07:51 PM
norvalwilhelm's Avatar
norvalwilhelm
They guy who suggested milling the mounting face of the water pump might have a good idea. Check that the pump clears the timing cover by a sufficient amount. That would be easy to do.
Turning the inside of the pulley is another but you already said it would make the pulley pretty thin.
I get around all this by just hogging out my own pulleys.
Old Mar 8, 2006 | 07:58 PM
Gordonm's Avatar
Gordonm
The pump is quite tight against the timing cover so I have no room to move tha tway. I would have to remove about .300 on an inch to make it work. This would not leave much material left on either the pulley or the pump shaft.
If I had a Bridgeport and lathe I would be making lots of parts. I'm lucky to have one side of the garage no less a machine shop.
Old Mar 8, 2006 | 08:20 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I had those same pullies they are for long water pump, I sold them and bought the correct set of March underdrive pullies for my Vette
