Cryogenics
Mike
http://www.alpinecryo.com/
Must be black majic. Theory sure doesn't explain it.
I think this may be one of those “it last three time’s longer because we said it did”
Kind of like the HUGE benefits of putting nitrogen in your tires.
You can not rearrange molecules. You are dealing with the unit cell, a body centered and body centered hyxagonal unit cells, retained austanite, MF and MS lines etc etc.
Temp yes can help to releave retain austanite, yes and high carbon steels after heat treating are put in a deep freeze to help transfermation of autanite to martinsite but the whole theory of taking do down , way down, leaving it for time and then a heating up cycle is
Save your money. If you insist on doing it get DRY ice from a local welding supply house and they do handle it and put your parts on it.
Temperature helps, not time.
This is all general information, not the fine details.
Must be. I don't enough about it to get into a full blown conversation about it. Now where are those witches at anyway
I'm sure if someone from NASA was here they could explain it.
) from the early days of high school shop class that tempering metals does exactly that. It rearranges the molecular structure during the heating anc cooling process. It has been way too many eons so I will say this only for discussion purposes. Can someone refute my statements with fact and not "I have a friend who says/saw/did etc"....?
Just curious.
Gary
Under the controlled processing no brittleness occurs and in fact the process is actually used to relieve residual stresses. With regards to brake components we've certified gains in excess of 300% in some situations on brake rotors (in fact, we do processing for several road racing teams as well as two F1 teams). It does not, however, seem to greatly affect pad life if they are treated.
We do cryogenic processing for several NASCAR teams, manufacturers (like Precision Industries, PSI, TCI, BTE, Edge Racing, Briggs & Stratton Motorsports, Pro-Built, etc), as well as a bunch of drag racers including some well-known Pro Stockers.
I would be happy to answer questions that any may have regarding the process; you can check our website too... We've got a couple of sections that we're redoing but they should be up in the next couple of days.
-Jeb Burnett, President
Deep Freeze Cryogenics, LLC
715 S. Arch St.
Little Rock, AR. 72201
www.deepfreezecryo.com
(501) 324-2796
http://www.metal-wear.com/racing_component_prices.htm
Who's going to step up and be the guinea pig?
715 S. Arch St.
(501) 324-2796
Thanks for the reply. For me, I'm not to terribly interested in brake rotors. However, what about other things were you really need some extra strength...such as con rods, piston pins, cranks, pistons,etc. These are the things you'd like to be extra strong so they don't grenade in your engine. SSBC sells cad plated steel rotors for about $135. That's a lot for a steel rotor. However, if the rotor fails, there's no extraordinary expense to replace it. With a con rod or crank failure at 6000 rpm in an aluminum block, things get a tiny bit more expensive. If the cryo freeze helps, is it applicable for internal engine components?..Opps. Didn't see the reference to your website. Maybe you answer these questions there.
they have a pricing section here http://www.deepfreezecryo.com/pricing.htm
If a Nascar team wants a frozen crank that's fine but it does not prove this treatment works, the actual experience with the gun barrels is interesting though. We need proof from an independant unbiased test lab
715 S. Arch St.
(501) 324-2796
Hey man....can you treat an engine block?
(If you haven't read my thesis, you won't understand).
