Pilot Bushing
Old Mar 9, 2006 | 02:20 PM
Beater's Avatar
Beater
Default Pilot Bushing
This should be an easy one. I'll be changing the clutch on my '79 L-48 this weekend. What size bolt do I need to pull the pilot bushing? I can't seem to find the info in my service manual (GM had a tool for it)
Also, the new pilot bushing that came with the clutch is not threaded. will this cause a problem (other than when I have to change the thing again)? Anything else I should look out for?
Old Mar 9, 2006 | 02:47 PM
evalu8r's Avatar
evalu8r
It should be smooth on the inside. Some guys will thread a large screw into the old one to pull it out. There is a tool for removing these, also the oldtimers will pack grease into the hole then drive a wood dowel in.
I've done all 3 and was easy.
Chris
Old Mar 9, 2006 | 02:54 PM
junkman104's Avatar
junkman104
Chris
Hey I resemble that. Also you can take a bolt and wrap tape around it untill it fits snug, pack with grease and drive it out.
Old Mar 9, 2006 | 03:54 PM
evalu8r's Avatar
evalu8r
Notice I said I've done all 3. Shady trees don't die they just don't have leaves on top.
Chris
Old Mar 9, 2006 | 05:39 PM
GTR1999's Avatar
GTR1999
Auto Zone has a slide hammer with 3 jaw internal puller that get them out quick and at no cost. Check the new bushing with a magnet to be should it's not magnetic.
Old Mar 9, 2006 | 07:45 PM
Beater's Avatar
Beater
I guess I was just getting confused with the whole oversized bolt thing. The owner of the vette shop in Des Moines ran through the process with me a while back, but that was monthes ago, and I forgot what size bolt to buy. This is the first time I've attempted this myself. Thanks for the info.
Old Mar 12, 2006 | 11:12 PM
Beater's Avatar
Beater
So I have everything basicaly back together. I had a heck of a time getting the new pilot bushing back in. It isn't in nearly as far as the old one, but certainly isn't going to fall out. Is this a problem? While the trans. is still out I want to make sure everything is set up ok.
Old Mar 12, 2006 | 11:25 PM
SIXFOOTER's Avatar
SIXFOOTER
as long as it is in far enough that the shoulder on the tranny input shaft is not interfering with it it will be ok
Old Mar 12, 2006 | 11:37 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Beater - I am in the middle of a automatic to 4 speed conversion and just installed the pilot bearing yesterday. I used an impact socket the same outer diameter of the bearing. I placed the socket over the bearing and hit the socket top-bottom-left-right until it bottomed out. There is a different sound when the bearing hits home.
Old Mar 13, 2006 | 02:45 AM
Beater's Avatar
Beater
I was using a socket and extension in much tha same way. It just won't budge. At this point I'm just bolting things together and I fix things when they become a problem.
Old Mar 13, 2006 | 03:09 AM
Retro78's Avatar
Retro78
put the bearing in the freezer before intalling. You might also want to polish it a little and use some oil.
Old Mar 13, 2006 | 07:47 PM
JJGoodwrench's Avatar
JJGoodwrench
Check these out. Sure beats all of the old methods of pulling bushings out. Cheap too!
JJ
http://www.springertool.com/
http://www.bc4x4.com/quick/2003/springertool/
Old Mar 13, 2006 | 11:58 PM
Beater's Avatar
Beater
The 5/8" bolt worked just fine.
I'm probably going to end up getting another bushing for $2 and trying the freezer idea. The thought crossed my mind, I just didn't act on it.
Old Mar 14, 2006 | 12:13 AM
ZO SIC's Avatar
ZO SIC
I always smear the inside of the crank and the outside of the pilot bearing/bushing with antiseize.
I also "had" to invest in a snap on pilot bearing removar. Similar tool to a steering collumn dissasmebly tool. $85 or $130 I forget, but I can't use the hydralic or "bolt" method on an LS1 motor. They have a "hollow" crankshaft with a freezeplug in there.
To Pilot Bushing
