71 Battery drain...
Old Mar 9, 2006 | 05:03 PM
67VetteMan's Avatar
67VetteMan
Default 71 Battery drain...
The 71 seems to be draining the battery... it will start ok for a number of weeks then the battery is too weak to crank the engine. Just put a new battery in at the beginning of the year. I know if the wiper override switch is on, there is a constant drain, but it is OFF.
Other than the clock, what else has a constant drain on the battery? How can I check for a drain?
Thanks,
Old Mar 9, 2006 | 05:06 PM
luerja's Avatar
luerja
my 71 had a starter solenoid that was draining the battery and having intermittent starts (it was shorting out). So i replaced it and everything is perfect.
Jim
Old Mar 9, 2006 | 06:26 PM
wnjlt1's Avatar
wnjlt1
67VetteMan,
you need to check for parasitic drain with a dvom (digital volt ohm meter) that can read in milliamps. setup the meter so that your reading it in amps (milliamp scale) then disconnect the negative battery cable and install the meter leads in series, one on the negative battery cable and the other on the negative battery terminal post then read the meter. i'm not sure what the exact draw would be but a new car with all the bells and whistles is around 25-35 milliamps. if you only have a clock then you should not have much draw. if it's excessive, you will need to start removing fuses and or individual components to locate the source of the draw. good luck!
Old Mar 10, 2006 | 12:18 PM
67VetteMan's Avatar
67VetteMan
Thanks, will do. I just happen to have an old Radio Shack handheld digital multimeter...
Old Mar 10, 2006 | 12:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've said it every time this has come up...but my 77 had a short in the starter coils. I never did figure out what the problem was, until I got so frustrated with the flaky starter that I ripped it out and replaced it with a BB502 starter. Lo and behold, my parasitic drain was gone. I know it wasn't the solenoid, because I had changed it.
Old Mar 10, 2006 | 05:02 PM
67VetteMan's Avatar
67VetteMan
One more thing to add to the list to get this solved... thanks for the suggestion.
Old Mar 10, 2006 | 06:25 PM
sjr1971's Avatar
sjr1971
With your DVM set to read current, the meters internal fuse is now in play. Meters typically max out at 2A. If you happen to hit the brake pedal while swapping fuses the current drawn will take out your meter's fuse. Just a thought . [Been there , done that]
Old Mar 10, 2006 | 06:34 PM
David Ey's Avatar
David Ey
also see this
http://forums.corvetteforum.com/show...082&forum_id=3
To 71 Battery drain...
