Transmission Modulator Valve. ? as to replacing
Old Mar 10, 2006 | 08:53 PM
73'454folendore's Avatar
73'454folendore
Default Transmission Modulator Valve. ? as to replacing
When replacing the Transmission Modulator Valve do I need to drop the tranny pan to put a c clip in place or does the gasket hold it in place to the tranny? Simple question because mine just blew out and drained the fluid down the driveway. Just got done installing the tranny and I think I might have missed something. like a c ring
Old Mar 10, 2006 | 11:56 PM
gator79's Avatar
gator79
turbo 400 has a bolt and a retainer plateon the exteror no need to drop the pan
Old Mar 11, 2006 | 02:44 PM
73'454folendore
What the f did he say?
Old Mar 11, 2006 | 02:53 PM
4ME+N73's Avatar
4ME+N73
The Modulator Has A Clamp Arrangement Similar To The Distributor Hold Down Clamp.
No Reason To Drop The Pan. Normally You Would Lose Some Fluid When You Pull The Modulator Out, But It Sounds Like That Has Already Happened.
Hold The Modulator Tight Against The New O Ring While Tightening The Hold Down Clamp.
Good Luck.
Old Mar 11, 2006 | 03:38 PM
73'454folendore
Good Luck.
This hold down clamp does not exist on any website or local auto part stores. I know I lost it when dropping the tranny. I will figure out a bubba clamp I'm sure. thanks
Old Mar 11, 2006 | 11:51 PM
gator79's Avatar
gator79
whoa looks like I missed a few keys.
should have read
the turbo 400 has a bolt and retainer plate on the exterior no need to drop the pan.
To Transmission Modulator Valve. ? as to replacing
