Strike Force smallblock alum heads
Old Mar 11, 2006 | 01:29 AM
Phil Zell's Avatar
Phil Zell
Default Strike Force smallblock alum heads
Any comments on these?
Good, bad, indifferent?
Old Mar 11, 2006 | 07:16 AM
79VetteMike's Avatar
79VetteMike
Pretty sure these are the same thing....
http://forums.corvetteforum.com/show...290&forum_id=3
Old Mar 11, 2006 | 10:09 AM
comp's Avatar
comp
Old Mar 11, 2006 | 10:34 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Ah yes Lucky Strike Force heads, the best heads to come out of CHina in a long time
Old Mar 11, 2006 | 01:37 PM
Solid LT1's Avatar
Solid LT1
If you want to be a "Beta Tester" for Chinese made goods go ahead. I will stick with kown and proven heads from AFR, Brodix, Dart, World, Edelbrock, Canfield, Trick Flow, and Pro-Action (now owned by Comp Cams), amongst others. I would feel "safer" about minor details such as valve seat retention, valve guides staying in place and other "MINOR" issues that have been comming out since the release of China Heads incorporated. Note the same seller also sells Chinese copies of Comp Cam rockers and other "Quality" parts for your Vette. If you buy the heads, I have a set of $200 shaft rockers for you just as good as Jessel or T&D stuff honest!
To Strike Force smallblock alum heads
