Flat tappet vs roller cam
Old Mar 12, 2006 | 02:27 PM
gve's Avatar
gve
Default Flat tappet vs roller cam
With all the talk about cam lobe failure should I buy a roller or flat tappet? The engine is a 454 10.5 com. pistons,torkerII, with a comp xe274s solid flat tappet cam. I have the engine apart, so now would be the time to make a change. I checked the lobes they are worn down .001 to .002, the engine has 1500 miles on it and I used valvoline 20w50 racing oil from the start. Is this wear normal for the miles? Thanks Gary
Old Mar 12, 2006 | 04:00 PM
Gordonm's Avatar
Gordonm
First off how are you measuring the lobe wear. You should be using a dial indicator with the cam being rotated on the bearing surfaces. You need to make sure there is no movement when you are spinning the cam. I just pulled a 294S solid flat tappet out of my 5K mile motor. It had less than .001 wear to almost no wear at all.
Would I go roller? If I had a spare 1K dollars around. I went to a larger solid flat tappet on my new 383 motor. The roller will give you a few more HP than the flat tappet but a solid roller will need attention and replacement of the rollers way more often than a solid flat tappet. Also you need less valve spring with a flat tappet. There are pros and cons of each you need to weigh them both and make your decision.
I have broken in many flat tappet cams and never had a lobe go bad. I remove the inner spring on my solid flat tappets for break in then go to the dual spring setup. Little easier on the cam breaking it in.
Old Mar 12, 2006 | 04:10 PM
gve's Avatar
gve
I used a dial indicator to measure the lobes, like you said. The cam specs are as follows:
Intake: .3340
Exhaust: .3400
Here is how the cylinders measured out
Intake 1 -332 Exhaust 1-340
2-330 2-340
3-332 3-340
4-330 4-339
5-332 5-339
6-330 6-338
7-332 7-339
8-330 8-339
Isn't it strange that the right cylinders all are lower on the intake?
Do you think this cam was possibly made this way?
Old Mar 12, 2006 | 04:14 PM
enkeivette's Avatar
enkeivette
I read an article once that claimed a 30hp improvement. Don't know if that's legit. I have a roller cam and I like it. But one thing to think about, you might need stiffer valve springs if you want to spin your engine to high rpm. The roller lifters are much heavier than the flat tappet ones.
http://www.chevyhiperformance.com/te...8_0307_roller/
Old Mar 12, 2006 | 04:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There is a much cheaper way to go roller than the retrofit parts. Look up a thread (that I started) from a few weeks ago that led to a discussion of using stock GM parts that are less likely to fail, anyway.
Old Mar 12, 2006 | 04:43 PM
Gordonm's Avatar
Gordonm
I would say that your cam has some wear on it. Like I said mine was less than .001 on all lobes.
It is real tough to compare a flat tappet to a roller. They are two completly diffent cams. Even if they advertise the same duration they will be quite different. The rollers get the valve off the seat much faster and stay at a higher lift longer due to the roller design.
Old Mar 12, 2006 | 06:42 PM
gdh's Avatar
gdh
how did your install go, are you happy with the results?
Old Mar 12, 2006 | 06:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Still gathering parts. Several members reported in with successful installations.
Old Mar 12, 2006 | 07:11 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
I went roller on my 454 and would definitely do it again.
Old Mar 12, 2006 | 07:30 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I've had them all and if you got a lot of green....then go roller. Don't tell your wife how much your spending, or your be buying a new bedroom suite, too.(ha) I have a Crane roller and I love it, but I think I dished out about 800 not counting labor. But, I never have to wonder how it would be with a roller, tho. Larry
Old Mar 12, 2006 | 08:21 PM
Brettmc's Avatar
Brettmc
I couldn't justify the expense of a roller compared to a flat tappet. Plus, I've never owned a solid lifter cam. So, I got one. Glad I did too.
Brett
Old Mar 12, 2006 | 08:47 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
INHO if you want to go to a roller cam, then a solid roller is the only way to go.
This because a hydraulic roller will give you minimal if any gains at all over the same duratation solid lifter flat tappet cam and you will pay 3-4 times as much for it.
As a matter of fact if you put 1.6 roller rockers on the mechanical flat tappet cam if would out perform a similar duration hydralic roller cam
Now if you don't want to put a mechanical cam in for what ever reason then a hydraulic roller is a step up from a hydraulic flat tappet cam
Old Mar 12, 2006 | 10:08 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Must have been a different article.
Originally Posted by torqvette
I read an article once that claimed a 30hp improvement. Don't know if that's legit.... http://www.chevyhiperformance.com/te...8_0307_roller/
Read that article twice - nothing 'bout 30hp more.
No flames torqvette, but u need to be careful making claims without using references to back it up. Hearsay kind'a feeds on itself as we all have the craving for more pwr. :o
But even with 30hp a $900 cam upgrade is close to $30 per pony - not cheap. And if u really only get 10hp it becomes an expensive dissapointment.
cardo0
Old Mar 12, 2006 | 10:26 PM
w1ctc's Avatar
w1ctc
As far as the cam measurements go there is a +/- tolerence on any part. Your cam could very well been that way from the start.
Old Mar 13, 2006 | 08:53 AM
Ed Blue 03's Avatar
Ed Blue 03
Brett
Yep, me too.
To Flat tappet vs roller cam
