What motor oil do you use?
Old Mar 12, 2006 | 09:36 PM
69L88clone's Avatar
69L88clone
Default What motor oil do you use?
I'm looking for a recommendation on a motor oil. What do you guys use?
Thanks in advance.
JIm
Old Mar 12, 2006 | 09:45 PM
PRNDL's Avatar
PRNDL
sorry, need pics of the car before I can reply!
Is it a high compression L88 clone engine?
I think we are developing a consensus that we are supposed to use deisel oil for these old bigblocks. I am looking for that Shell Rotelle stuff, but they only sell it at truck stops!
Old Mar 12, 2006 | 09:50 PM
Brettmc's Avatar
Brettmc
I use Mobil Delvac 1300S. I got it at Advance Auto. $7.98/gallon.
Brett
Old Mar 12, 2006 | 09:52 PM
69L88clone's Avatar
69L88clone
Photo link:
http://jpascale.photosite.com/69Vette427/
12.5 to 1
Huh?
Old Mar 12, 2006 | 09:57 PM
69L88clone's Avatar
69L88clone
Oops! Didn't respond correctly. My reply appreared in your qute.
photos? Here:
compression: 12.5 to 1
deisel oil? I've been off this site to long. Please tell more.
Old Mar 12, 2006 | 09:59 PM
69L88clone's Avatar
69L88clone
Brett
So PRNDL wasn't pulling my leg. Is there an old thread on this issue? I need to catch up with you guys.
Jim
Old Mar 12, 2006 | 10:14 PM
thermoquad's Avatar
thermoquad
i think a lot of members use zaino z-5, but i also think some brush their teeth w/zaino or maybe sleep w a bottle of zaino
personally, i use valvoline 10/40--wouldn't put any synthetic in one of these older sbc engines except after a complete rebuild given the way most of 'em want to leak at one end or the other--i think about any name brand dino oil will work if you change it every 3-5K miles and drive it like you stole it
good luck
Old Mar 12, 2006 | 10:37 PM
goinbroke's Avatar
goinbroke
Here's a recent thread that may help.
http://forums.corvetteforum.com/show...697&forum_id=3
Old Mar 13, 2006 | 08:19 AM
pws69's Avatar
pws69
Thanks in advance.
JIm
Mobil 1 15W50
Old Mar 13, 2006 | 09:07 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I either use Royal Purple 10W30 or Mobil 1 10W30 with K&N oil filters
Old Mar 13, 2006 | 12:02 PM
69L88clone's Avatar
69L88clone
I thought about using Mobil 1 with a supplement of ValvolineSynPower Oil Treatment. But I posted a question to the mobil1 techs about this & this is the reply I got:
Mobil does not recommend the use of any oil additives with Mobil motor
oils. Theses products are not licensed and alter the chemical balance
and formulation of the motor oil.
So, I'm still not sure what to use.
Jim
Old Mar 13, 2006 | 12:15 PM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
Mobil 1 10w-30. 4 years now...stil no problems.
Old Mar 13, 2006 | 12:32 PM
gonzo14's Avatar
gonzo14
newly rebuilt original motor 3 years ago, body off restore done at the same time period, wouldnt choose anything but Mobil 1 (10w-30). If storing it during the winter months, put a quarter to half of a quart of Lucas stabilizer in it also. Make sure to use either an ac-delco oil filter, or a wix filter. K&N are great also, but expensive. I do have a K&N air filter, just because its more permanent (just needs cleaned every now and then). Change the oil before and after storage. (at least thats what I do).
Old Mar 13, 2006 | 12:38 PM
Robert B. Barwick's Avatar
Robert B. Barwick
Royal Purple 10w30 K&N filters
Old Mar 13, 2006 | 01:17 PM
yukon988's Avatar
yukon988
It looks like there are a lot of Mobile 1 users here. Does anyone know how much zinc is in Mobile 1? mountainmotor listed the zinc content of many oils in another thread but I didn't see this one listed. I found one web site that claims around 800ppm which, if true, would be a bit low for engines without roller cams according to some of these past threads.
Old Mar 13, 2006 | 01:21 PM
norvalwilhelm's Avatar
norvalwilhelm
Right now I am using Shell. Price club had it on for $1.50 a quart so I bought 100 quarts.
10-30 dino oil here. NO sythetic.
Old Mar 13, 2006 | 01:30 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Delo 15w40 oil for diesel engines. I buy it by the case at Costco, but you can find it along with Rotella at Walmart, GIJoes, etc.
To What motor oil do you use?
Old Mar 13, 2006 | 01:39 PM
vettfixr's Avatar
vettfixr
Mobil 1 10w-30. Been using it for at least 5 years with no problems. Engine is original block and reciprocating assembly that was freshened with new rings and bearings. The only leak I have is a very slight drip from the rear main seal but I think that's standard equipment on these cars.
Old Mar 13, 2006 | 01:41 PM
b71vette's Avatar
b71vette
Right now I have Valvoline 10w30 standard grade, after reading all these threads I am going to switch to Valvoline VR1 10w30 Racing Oil to bump up to a higher zinc content, I have a mechanical roller cam, but with the money I have in the engine decided I would use a higher grade oil. Using Wix Race Filter.
Old Mar 16, 2006 | 01:41 AM
glen242's Avatar
glen242
Valvoline 10W-30 racing oil and Wix (NAPA) filters.
