reverse polarity
Old Aug 14, 2001 | 10:05 AM
dogboy's Avatar
dogboy
Default reverse polarity
What exactly is reverse polarity and how do you fix it? I rebuilt my alternator the other day with the 80 amp upgrade kit and now my battery is failing. I notice the voltmeter in the dash will drop to 8-9 when a/c is on and at idle. if all else is off the meter will stay at about 13 or the middle. I'm not sure if its related but the battery has 20mths of life so far?
Old Aug 14, 2001 | 11:43 AM
KenSny's Avatar
KenSny
Default Re: reverse polarity (dogboy)
Reverse polarity means you connected + to - and - to +. Double check all your connections. Make sure nothing is shorted to ground.
