82 with 2 wire CTS -where to ground?
Old Mar 13, 2006 | 07:43 PM
MN-Brent's Avatar
MN-Brent
Default 82 with 2 wire CTS -where to ground?
Im putting in the 2 wire 84 Coolant Temp Sensor with plug/pigtail in the 82 and would like to hear from those that have done this where you connected the new ground-for good reliability & convenience.
For those that havent done this, the 82 original is single wire and grounds through the body of the sensor-not with the second wire.
Appreciate any replies.
Brent...
Old Mar 13, 2006 | 07:50 PM
jdp6000's Avatar
jdp6000
There should be two wires...just wired a little differently. Look in the harness...the other one should be there.
If it helps. Manual shows a yellow to the ECM. Black grounds to the same ground as the TPS.
Jim
