Tune up Time Please help
Old Mar 14, 2006 | 09:21 AM
kodaclr's Avatar
kodaclr
Default Tune up Time Please help
Ok The backyard machanic is at it again. I have a stock 1969 350, 300hp. auto, I need to give it a good tune up. I have changed plugs and oil at the start of each of the last 2 summers. This will be my 3rd with the car and I think it needs a good tune up.
Here is my check list.
1, new plugs
2. new Plug wires - need suggestions of brand please
3. new rotor & dist. cover - brand?
4. Point & Condenser - NAPA
5. Timing - Read Lars paper
6. ReCurve kit - NAPA? (Read Lars papers)
7. Oil change
8. Check All fluids (Rad, Trans)
I have been doing searchs on some of this stuff for suggestions on bands Please let me know if I am missing anything and please, please make suggestion.
Thanks you very much for any and all help.
Old Mar 14, 2006 | 10:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My advice is to stick with the 7mm Delco stock plug wires. If you can't get them across the counter, the Corvette aftermarket providers carry them. Stay away from "universal fit" plug wire kits. If you're still running the original plug wire looms, anything bigger than 7mm won't fit.
Old Mar 14, 2006 | 10:04 AM
76greg's Avatar
76greg
How about a new fuel filter. If an auto trans, a new filter in there as well and a flush with new fluid.
Greg
Old Mar 14, 2006 | 10:16 AM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
1, new plugs
7. Oil change
Fuel filter
breather element (if applicable)
PCV
air filter
carb&choke cleaned and adjusted
auto-tranny filter and oil change(if applicable..not just *checking* fluids)
replace coolant--( add *40below additive* if applicable)
rear diff oil change with posi-trac additive
I use AC Delco platinum plus plugs (high $$)
You can use Jeggs or Summit (or local) that sells Accel or Mallory ignition products (dist. cap, rotor, points, condensor).
Adjust correctly or change belts that provide power and correct cooling (water pump/alternator)
Jim
Old Mar 14, 2006 | 11:17 AM
kodaclr's Avatar
kodaclr
Fual filter was changed last summer which caused a Carb rebuild because I striped the threads. So I'm a little gun shy to change the filter again, but I will try everything else you guys have suggested.
For the trans fluid and filter, are there any secrets. I have read about changing fluid and filter, sounds to easy.
Old Mar 14, 2006 | 11:27 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
1, new plugs
7. Oil change
Coil, fluids in the diff, dont forget fuel and air filters ( i have two in my 68, one in the carb, plus the cannister)
Old Mar 14, 2006 | 12:10 PM
SIXFOOTER's Avatar
SIXFOOTER
More on Lars post about what points and condenser to run, some are junk
Old Mar 14, 2006 | 12:27 PM
desi's Avatar
desi
...I have changed plugs and oil at the start of each of the last 2 summers. This will be my 3rd ...
How long is summer there? I change oil/filter every 3 months or 3K miles which ever comes first
Old Mar 14, 2006 | 12:43 PM
kodaclr's Avatar
kodaclr
Sixfooter
When you say more on Lars post, what do you mean? is there a link?
desi - summer is 3 months if were lucky, no but I only weekend drive so I probably on get about 3000 miles.
Old Mar 14, 2006 | 12:59 PM
SIXFOOTER's Avatar
SIXFOOTER
Quote from Lars
For parts use NAPA part number CS786 for the points and RR175 for the condenser. I check my dwell once a year, and it hasn't changed in 3 years.
Thats from a post a week or so ago
Old Mar 14, 2006 | 01:06 PM
kodaclr's Avatar
kodaclr
Sixfooter - Thanks those are the numbers I have, I think from the same post.
Another dumb question, I just checked NAPA site and they have a CS786 and cs786 HD, I assume I use the CS786 because I have a pretty stock 350 300 HP eng., Is this correct?
Old Mar 14, 2006 | 01:13 PM
68sbShark's Avatar
68sbShark
While you are at it, you should probably go through the brakes as well. Check the pads, flush/replace the fluid as well. Who knows when the last time this was ever done.
~Rich
Old Mar 14, 2006 | 01:16 PM
kodaclr's Avatar
kodaclr
68sbShark
Did a total rebuild of the brake system, new MC, rebuilt calipers with o-rings, new pads and all new lines and blocks.
Old Mar 14, 2006 | 02:14 PM
68sbShark's Avatar
68sbShark
Guess you are one step ahead then. Now get back to work on your car!!
~Rich
Old Mar 14, 2006 | 03:36 PM
kodaclr's Avatar
kodaclr
Thanks everyone
To Tune up Time Please help
