Adding air conditioning
Old Mar 14, 2006 | 11:54 AM
cal camara's Avatar
cal camara
Default Adding air conditioning
I am considering adding air conditioning to my 72 base engine convertible that I am working on. Ok I know who needs air conditioning in a convertible. I live in the desert and my wife has the early stages of MS, and she needs air conditioning or the desease effects her more. She likes to drive and ride in the vettes we own, she drive a 90 vert as her daily driver. She rides with the tops up most of the time.
My question is has anyone put in an after market air system that works and still appears stock.
cal
Old Mar 14, 2006 | 12:04 PM
DaveL82's Avatar
DaveL82
There wasn't a direct bolt in aftermarket system out there last year when I looked. However I would contact Vintage Air since there were rumors they had one in the works.
Their small system moves all heater, defrost and AC into one unit that might just fit under your dash (top right area). Not sure if you have a glove box and if so you may loose storage in it.
I have an 80 with factory AC which is not the best. I've consider an integrated system like Vintage air since it would allow me to remove the huge box from inside the engine compartment and run a better compressor with new 134 freon. I could get mine to work OK but would rather just replace it.
Dave
Old Mar 14, 2006 | 12:08 PM
DC118us's Avatar
DC118us
I think one of the Vette companies sells an aftermarket setup designed to work with the original controls.
Old Mar 14, 2006 | 12:37 PM
cal camara's Avatar
cal camara
Default unit at Ecklers
Ecklers addvertises a unit for 68-82, that suggests bolt in, anyone know anything about that one?
cal
Old Mar 14, 2006 | 01:14 PM
1mollyd's Avatar
1mollyd
cal
I'm currently installing a kit from Classic Auto Air which is called a "Perfect fit system" and is listed for '68 - '76 Corvette.
It is a compact unit which fits behind the passenger side dash and does not hang into the engine compartment as the stock one did. It uses a Sanden compressor and it uses the riginal controls in the console.
I can't say how it works yet as I haven't completed or tested it, but it looks pretty good.
Dave
Old Mar 14, 2006 | 02:14 PM
DaveL82's Avatar
DaveL82
There is a thread on this topic in the general C3 forum.
Old Mar 14, 2006 | 03:18 PM
cal camara's Avatar
cal camara
Default Where?
What is it called I can't seem to find it.
thanks
cal
Old Mar 14, 2006 | 04:24 PM
1mollyd's Avatar
1mollyd
thanks
cal
Here's one link.
http://forums.corvetteforum.com/show...tix&forum_id=3
There may be others.
Dave
Old Mar 14, 2006 | 04:28 PM
gdh's Avatar
gdh
It is a compact unit which fits behind the passenger side dash and does not hang into the engine compartment as the stock one did. It uses a Sanden compressor and it uses the riginal controls in the console. I can't say how it works yet as I haven't completed or tested it, but it looks pretty good.
Dave
Dave did you order it from the US or is there a cdn distr. Do you have pics of your instal, I am looking at doing the same next year.
Greg
Old Mar 14, 2006 | 04:39 PM
1mollyd's Avatar
1mollyd
Greg
I ordered mine from the US. I think they're in Florida.
I don't have any pics of the install but it's pretty straightforward. Anyway I'm only about halfway thru my install. I still have my engine and rad out so I can't really fit up the compressor or condensor yet.
I think there are quite a few pics in the other posts if you do a search.
Shoot me question if there's anything else.
Dave
Old Mar 16, 2006 | 01:24 PM
cal camara's Avatar
cal camara
Default Thanks all
cal
Old Mar 16, 2006 | 03:33 PM
carriljc's Avatar
carriljc
Default I installed Hot Rod Air....
some pics off to the left here:
Be aware that Hot Rod Air "patient" about their orders, but it wasn't a problem for me since I could only work in short stints. Works wonderfully and used the original controls. Had to fabricate the center ducting on my 68 since the ducting they sent would not have fit...just used some PVC; cut and glued to make it fit.
Old Mar 16, 2006 | 03:58 PM
Jims79's Avatar
Jims79
Cal, if you havn't found it by now there is an outfit called Vintage Air and they make AC units to fit all kinds of classic's, hot rods and vettes
Let us know how you mk out. Its one of the mods I'm thinking about in the future.
Old Mar 16, 2006 | 07:09 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I'm in the middle of a Hot Rod Air install in my 79. They are laid back, but I'm doing about 12 other projects to the car so it's OK. The product, support, & instructions are top notch. If you buy from them, mention CF & suggest they become supporting vendors.
Old Mar 17, 2006 | 11:20 AM
cal camara's Avatar
cal camara
Default Vintage Air
They do not have a listing for units pasted 67 corvettes
cal
Old Mar 17, 2006 | 11:23 AM
cal camara's Avatar
cal camara
Default Whjat is a boy to do
There is Hot Rod Air
Classic and Vintage, How do you know which is better, everyone seems to like them
cal
Old Mar 17, 2006 | 01:13 PM
wes weigle's Avatar
wes weigle
Default Old Air Products
I Put In A System That Was Manufactured By A Company Call Old Air Products In My 1964 Vette Several Years Ago. I Got The System In A Trade Deal. For The Most Part I Was Frustrated With The Products Fit And Instructions Which Were Not Very Clearly Written And Left Outcomments On Issues That Should Have Been Addressed. Additionally, I Called Them For Some Advise And Their Customers Service Was Worthless. The System Does Work, But Knowing What I Know Now About The Installation Process And The Modifications And Things I Had To Do To Make It Fit And Work, I Would Not Recommend Their Product.good Luck!
To Adding air conditioning
