Tach Drive Distributor Question....
Old Mar 14, 2006 | 06:37 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Tach Drive Distributor Question....
I have to replace the main shaft due to excessive wear at the bottom bushing. Is it necessary to replace the cross shaft too? It appears to be OK.
thanks
Old Mar 14, 2006 | 08:18 PM
audiec's Avatar
audiec
When I tore into mine, it needed both. I ended up rebuilding the entire distributor while I had it out.
Audie
Old Mar 14, 2006 | 11:06 PM
mbeeman350's Avatar
mbeeman350
Audie
I've been through this before...on my last vette. In that case the cross gear stripped out and took out the main shaft with it.
Old Mar 14, 2006 | 11:09 PM
big_G's Avatar
big_G
If the main shaft is worn, the bushings are probably toast, too.
Old Mar 15, 2006 | 01:22 AM
kdf1986's Avatar
kdf1986
depending on the age of the cross gear, you might want to replace that for your own piece of mind.
If you are going to pull the main distributor shaft, why not do a total refurbishment job with a new shaft, cross gear, brass washer and bushings. That way when it goes back together you will know that everything was replaced and is new. If you know that the cross gear has been replaced several months ago, then I would skip this step. But if you really dont know the age, then why take chances if you can avoid it.
kdf
Old Mar 15, 2006 | 07:37 AM
mbeeman350's Avatar
mbeeman350
kdf
That's my plan. I have the bushings and shims, vac advance, etc. I just ordered both gears, to be sure everything matches up. thanks
Mark
To Tach Drive Distributor Question....
