Engine number help
Old Mar 15, 2006 | 09:26 PM
windsoreight's Avatar
windsoreight
Default Engine number help
The engine west south in my recently acquired 79 vette. I am pretty sure the motor is not the factory. I pulled the numbers on the rt frt of the block. 12J179724 & TI208CKP . I wiped a cam lobe and I would like to know if this is something worth building? So if anyone can help. Is there anywhere else to look? Thanks.
Old Mar 15, 2006 | 09:32 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
well any SBC motor is a good potential to rebuild.....why do you think you wiped a cam lobe?
Old Mar 15, 2006 | 09:44 PM
windsoreight
Because the lifter is pumped up and the rocker arm is not moving. It is popping through the carb. Looking like #8 intake lobe is shot. I don't think I will be able to save the motor. Upon further inspection there is a 6 inch crack on the side of the block that has been welded up. I just wanted to know what I had. I really don't have time to rebuild so I think I will give Jasper a call tomorrow.
Old Mar 15, 2006 | 09:55 PM
audiec's Avatar
audiec
The book I have says that when it was origional the motor was:
1972, 400cid, 170hp, 2bbl, Caprice, Turbo Hydromatic Trans.
The casting numbers listed should be on the left side by the trans housing should be one of the following:
330817 - 2-bolt main
3030817 - 2-bolt main
3951509 - 2-bolt main
3951511 - 4-bolt main
Excellent motor, 4.125 standard bore, this is the engine the 383 got its torque from.
Audie
Old Mar 16, 2006 | 08:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by windsoreight
...I am pretty sure the motor is not the factory. I pulled the numbers on the rt frt of the block. 12J179724 & TI208CKP...
You are correct. The numbers are not for a Corvette engine.
To Engine number help
