The advertisements for Vortec heads cite a 30hp increae over stock heads. Are the they referring to the smog heads on my '80?
How do Vortec heads compare to the double hump 186's or the 041's (with 194 intake) that I have now. I'm considering the heads that Scoggin Dickey sells as a kit (will the Air gap work under a stock hood as well?)with stronger valve springs. Thanks for any input.
If you have a domed piston, such as those in the 350/350hp L46, I am advised by Scoggin-Dickey that the Vortecs, with their revised heart-shaped comb chamber, will NOT accomodate. If you are running flat-top (with valve reliefs) OR dished pistons, the vortecs will accomodate.
The vortecs draw upon the revised port designs of the 'Gen II' engines of the mid-90's (ex. LT4). So, comparing flow of the vortec vs. the 186, you will see improved flow/performance with the vortecs. The combustion chamber designs are also changed/improved.
Having said that, a good porting job, gasket match to intake, and 3-angle valve job on a rebuilt set of 186's will also yield visible performance improvements... This is what I will be doing with my 350/350hp along with guides and hardened exhaust seats as I do not intend to remove the stock domed pistons (11:1). Price I am quoted is $250 plus $8 per valve guide...
Thank you Ted. The short block I'm using has flat top pistons. I believe it's a bout 9.5 compression or a little lower. I used the burret and did the calculations. What a mess.
I know the hood clearance question is brought up frequently, but does an intake really sit any higher on Vortec heads than the stock heads?
I believe that the intake manifold manufacturers will provide (via website) the height characteristics of their respective intake manifolds. Having said that, as long as the height iof the intake is equal to or less than the Edelbrock Performer (2101 or 3701) intake, you SHOULD be ok.
My understanding is that the vortec heads themselves do not cause an intake to sit higher than the OEM style heads. But, to be safe, I would inquire with Scoggin-Dickey's tech line via their website. They are very good at investigating and responding to inquiries. I got the info on the domed pistons and vortec head clearance from them in 1-2 days.
Does your 250 include porting???? That seems cheap
As for the 041's you can put bigger valves in them and make good power for not too much cash.
If you are planning on changing your intake and valves anyways, you might consider the vortechs.
I know the airgap will fit with stock heads, but I am not sure about the Airgap that is made for the vortechs. I would call edelbrock or summit and ask them, as they have the height specs.... You might even find the specs on their sites.
The Airgap RPM fits, but not without modifications. I had to run a 2in airfilter dropbase with a 3in tall air filter and cut off my choke tower. I also had get rid of my carb stud, as the wing nut hit my hook. You can just use a regular bolt. I have about 1/8in of clearance
I was told it would not fit by edlebrock when the manifold came out. After a little tinkering it fit fine
Oops. Sorry. Porting and gasket match is extra. The $250 does include the 3-angle valve cut though. Also cleaning and resurfacing the heads and hardened exhaust seat inserts.
How about this... If I just go with the Vortecs and the Edelbrock Performer intake, would there be much of a difference between the Performer and the Air Gap? Thanks!
Suggest DO NOT put "Guides" in IRON sbc heads unless they cannot be tightened up with "Liners" ... liners are thin wall bronze tubes ... guides are bulky and usually end up extending into bowl & restricting flow ... liners do not ... liners are easier & cheaper to install ... and last a LONG time. NO BODY , NONE around here with any experience use guides in race classes requiring production iron heads ... liners only.
It realy depends on what cam you are running. You could use either intake with Vortecs or stock heads. The Performer will make power at a lower RPM and have a little more low end torq. The RPM intake will make more power overall, but it will make it later in the rpm range. Like I said it depends on what cam you want to go with. I usualy choose what kind of power band I want, then choose a cam to match it. Once the cam choice is made I build the rest of the motor around the cam.
P.S. A good head porter will ask for your cam card and build your heads to the cam.
Good info to know. I'll verify what the shop would be doing in regards to any guide repair that is required. I don't participate in any organized racing with the L46. Although, I may take it to another machine shop that is more oriented toward high performance machining at the recommendation of a friend.
