Keisler TKO Driveshaft Alignment HELP!!!
Old Apr 7, 2006 | 08:20 PM
  #61
norvalwilhelm's Avatar
norvalwilhelm
I pulled the driveshaft tonight and I have a yoke with a machined flat plate welded to the yoke and trued in a lathe. I carefully measured the yoke angle. This is with the top of the tremec almost touching the tunnel, no way to get a finger inbetween .
I got 4 1/2 degrees DOWN so that is what the rearend is but up.
Old Apr 7, 2006 | 08:21 PM
  #62
shafrs3's Avatar
shafrs3
Originally Posted by hawgn68
The problem is the verticle alignment. Both my tailshaft and pinion are pointing at the floor...negative angles. To get the pinion level, I have to remove the donut entirely. My other option would be to shim the 4 mounting bolts to the rear crossmember. This just seems wrong. To level the trans tailhousing, I need to shim the tran mount by an inch. I can do this a number of ways, but I'm worried it will hit the tunnel when the body is put on. Any suggestions?????????
Jim
Does all this matter that much? I've just installed mine without going through all these measuements and it's working great, no vibrations. What's the chances I got all these measurements right?
Yes the tunnel clearence is tight, using the keisler supplied trans mount I've got about an index finger's width between the tunnel and the rear inspection cover with the original 1972 non-rubber body mounts.
Old Apr 7, 2006 | 09:04 PM
  #63
hawgn68's Avatar
hawgn68
Shaftrs,
I'm leaning that way. Universal joints are cheap. My problem is that with the body off, I don't know how much I can jack up the tailhousing without it hitting the tunnel. I think I'll just try and get the differential close to level, then when the body is on, shim the trans mount until it's up against the tunnel.
Jim
Old Apr 7, 2006 | 10:58 PM
  #64
shafrs3's Avatar
shafrs3
It's easy to go up, I've got just enough space for the auto transmission tunnel blanket. And if you've opted for the heavy duty transmission yoke keisler offers, and it appears that you have, that thing is big and restricts tail shaft positioning horizontally.
Old Apr 7, 2006 | 11:19 PM
  #65
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Thanks Norval. Any others?
Old Apr 8, 2006 | 08:06 AM
  #66
shafrs3's Avatar
shafrs3
I pulled the drive shaft tonight and I have a yoke with a machined flat plate welded to the yoke and trued in a lathe. I carefully measured the yoke angle. This is with the top of the tremec almost touching the tunnel, no way to get a finger in between .
I got 4 1/2 degrees DOWN so that is what the rear end is but up.
Thanks Norval, you went way out of your way to get this info.
Sometimes I just wonder if the threads get too caught up in the analysis and loose sight of what's working.
