I'm looking to start collecting some used speed parts.
I wouldn't be worrying about the plates over the water holes, but I would worry about this quote:
"IT HAS SOME DAMAGE WHEN IT THREW A ROD. THIS CAN EASILY BE FIXED IN A MACHINE SHOP AND WITH A NEW SET OF SLEEVES"
Sounds like another junk sell on Ebay to me.
Two things to look for when buying a sprint car block. A the best blocks are set up for dry sump oiling only. Some of them do not have any drain back in the valley over the cam/crank and are wet sumps. This may be an issue depending on your app. B most of them have been wounded. This is not an issue as long as it is a pan/sleeve repair. If it is in the mains or especially the lifter bores it has had it and should not be repaired. The fractured mains are debatable but most racers will not run them if they have been hurt there. Best bet is to find a good Rodeck 350+ that is set up for wet unless you want to run dry sump but you will be locked into that. They are the strongest available by far!
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
* dry sump
* no motor mounts, only for motor plate
* no fuel pump boss (improved #2 cyl. cooling)
* no main caps
* damaged
* set up for remote water pump w/ side hookup instead of front
* dry sump
* no main caps
* damaged
i thought it was relatively easy to convert from dry sump to wet? Just a different rear cap?
good catch on the motor mounts. I would not even had bid if i had noticed that.
I was hoping i could drill holes to convert it back to a stock water pump.
a pontiac block is not my first choice. I just thought i could pick it up cheap and play with it.
If you want an aluminum block, why not just convert over to an ls1? They can be bought for fairly cheap, wont need to be repaired or modified heavily modified like most of these ebay junks. The stock ls1 is very durable. Internals are good to 500rwhp and 6500rpm. You can carb them if you dont want to deal with all the wiring junk.
