Transmission Pan Gasket
Old Mar 19, 2006 | 08:30 PM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
Default Transmission Pan Gasket
Does FelPro make a Perma-dry gasket for the trans pan?
I have a persistant leak from the front right that's pizzing me off! I replaced it with a standard FelPro rubber, but I still get the occasional drip.
The Perma-dry gasket I put on the engine oil pan is fantastic! I was hoping there was an alternative.
Old Mar 19, 2006 | 08:43 PM
carl a's Avatar
carl a
i put the top of the line from car quest,,it has a metal body inside the gasket to keep it from seating incorrectly.....i do not have a drip or a film on my pan and its a aftermarket deep b& m pan w/ drain plug and its chrome which have a tendency to have leaks,,,i roughed the lip on the pan in a crosshatch pattern w/ 80 grit sandpaper before installing carquest gasket
Old Mar 19, 2006 | 08:56 PM
TonySinclair's Avatar
TonySinclair
What trans do you have?
I tried the FelPro Perma-Dry on my TH400 after two unsuccessful attempts to seal. Finally switched to a cast aluminum pan and the FelPro Perma-Dry...with a light dusting of gasket stickum...the bastard still leaks.
Old Mar 19, 2006 | 09:15 PM
carl a's Avatar
carl a
tony,,try the carquest (metal inside) gasket worket for me
Old Mar 19, 2006 | 09:26 PM
TonySinclair
Thanks but, I ain't doing it a 4th time! I'll live with it until I do a major overhaul...
Old Mar 19, 2006 | 09:33 PM
blctalon's Avatar
blctalon
Just a thought..I had a leak coming from my transmission not too long ago and I thought it was a pan gasket. It turned out to be a combination of 3 little leaks: dipstick tube, kickdown cable, and tailshaft.
Old Mar 19, 2006 | 09:42 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Mine leaks out of the speadometer cable connection. I think my pan leaks also. I've never had problems with cork gaskets(knock on wood) so thats what I use.
Old Mar 19, 2006 | 10:05 PM
carl a's Avatar
carl a
I Hate The Slightest Hint Of A Leak And Wil Do What It Takes To Correct Its A Vette Not A Harley
Old Mar 19, 2006 | 11:25 PM
murvette's Avatar
murvette
After 3 gaskets and I think I should not be turning wrenches it was the shifter seal .Its not always the gasket. replaced the spedo seal and dipstick thought I hai it covered . I will bet there more places that leak that i havent had the pleasure to find.
To Transmission Pan Gasket
