It's In AND Running!
Old Mar 19, 2006 | 10:45 PM
nastee383's Avatar
nastee383
Default It's In AND Running!
I'll be brief. The motor I was having trouble with, it would crank but not start, is installed and running. I am somewhat embarrassed to say I believe I wasn't giving it enough fuel to fire initially. I would pump the throttle 5-6 times but that apparently wasn't enough. To get it to fire I had to pump the throttle about 10-15 times. After it warmed up and ran for a few minutes it would start right up without pumping the throttle at all.
Sorry it took so long to resolve and I appreciate all the input, but as usual it was something pretty basic. I may have never figured it out if I hadn't taken it to the dyno. It was hard to start there also initially. He assured me he just needed to give it more fuel and sure enough it started. I did alot of work when all I had to do was pump the accelerator a few more times. :bb
Old Mar 19, 2006 | 10:53 PM
big_G's Avatar
big_G
Now I can finally get some sleep!
Old Mar 19, 2006 | 10:58 PM
JoeRags's Avatar
JoeRags
good to hear your up and running....
Old Mar 20, 2006 | 03:50 AM
enkeivette's Avatar
enkeivette
I'm guessing you have no choke? But still 10-15 pumps seems like a lot, did you make sure the bowls were full before you tried to fire it up? 10 of those 15 pumps might have been squirting in air.
Old Mar 20, 2006 | 04:27 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Any more than 3 pumps and I'll flood my carb.
Old Mar 20, 2006 | 10:04 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
something is not right....maybe the accerelator pump is shot
Old Mar 20, 2006 | 12:18 PM
nastee383's Avatar
nastee383
I have an electric fuel pump that primes when the key is turned on. I'd do that 3-4 times and the bowls would fill up midway of the sight glasses. Then I'd pump several times. It has a choke. Evidently the excessive pumping was necessary because the motor had been sitting for a couple of months. After it fired subsequent starts only reqired one or no pumps of the accelerator.
Old Mar 20, 2006 | 12:21 PM
nastee383's Avatar
nastee383
It's a brand new carb so I don't think that was it. Like I said after it finally started only one or no pumps were needed to refire.
Old Mar 20, 2006 | 12:23 PM
nastee383's Avatar
nastee383
Thanks, now to get the loose ends tied up and take this thing on the POWER TOUR, Long Haul of course!
Old Mar 20, 2006 | 12:30 PM
C3 4ME's Avatar
C3 4ME
congrats on finding the problem. I assume you mean it only needs a few pumps or none even when cold, right? wouldn't want to get caught on the power tour having a problem.
Old Mar 20, 2006 | 12:54 PM
bobs77vet's Avatar
bobs77vet
good to hear...i must have misread your post...if its fixed now thats all that matters..and i'm glad its running strong
To It's In AND Running!
