76 Vette Head light problems
Old Mar 20, 2006 | 04:24 AM
Thmprr's Avatar
Thmprr
Default 76 Vette Head light problems
When I bought my Vette, I did not need to use the Head lights for some time, so I was surprised that the lighting was pathetic when I did need them.
I thought I would fix that by fitting halogen bulbs, 55W which did do a much better job of lighting, but now I have a problem, the lights are bright when first switched on, but then get dim, then flicker, I thought it might be the dimmer switch, but that has not helped matters.
Do the 76's have a headlight relay, if so where is it located?
Any help would be great, as we are closing on the winter monthes, down here downunder.
Old Mar 20, 2006 | 11:10 AM
Dragonwycke's Avatar
Dragonwycke
1. have the battery tested- maybe its getting into it's 'final days'.
2. check alternator output @ 1500 rpm. Flickering/dim usually occurs at idle and levels out (up) at or above 1500. Should be charging at 13.5 to 14.5 volts.
Old Mar 20, 2006 | 02:16 PM
Boofers's Avatar
Boofers
Like Dragon said, its normal for the lights to go dim at idle. Additional electrical loads like big stereo amplifiers or electric fans will make this problem more noticeable and you may have to upgrade you alternator to a higher current one.
Sounds like your lights are losing voltage, due to something in the path getting resistive or opening. Start with a visual inspection of the wires and see if you can find any signs of rubbing or wear.
You may want to make sure all the electrical connections are clean & tight; places like the bulb sockets and the contacts of any electrical connectors. There should be no dirt or oxidation and the connections should be tight. If you notice the lights flickering when you go over bumps this would be a promising avenue of investigation. Use sandpaper if you have to.
If you don't find anything obvious with the visual inspection start probing around with a voltmeter. If you find a component (like a switch, connector or wire) that has +12V in but way less out, thats probably the problem.
Old Mar 20, 2006 | 02:34 PM
SIXFOOTER's Avatar
SIXFOOTER
Check this out. This is the correct answer for headlight brightness
http://www.madelectrical.com/electri...adlights.shtml
Old Mar 20, 2006 | 04:27 PM
Pete76Shark's Avatar
Pete76Shark
I agree with sixfooter...I have it and it made a big difference
Old Mar 21, 2006 | 06:12 AM
Thmprr's Avatar
Thmprr
Default I Agree
This is what it needs, relays fitted, going to get them fitted asap.
Battery and alternator are fine, the clue is the bright lights when switched on, then reverting to a pulsing dim light, this is caused by the bi metallic strip preventing overload of the switch.
By fitting relays, the only duties of the dimmer switch and light switch will be to trigger the relays.
On another matter, the fuse panel is hard to see, is there a trick I am missing, i.e. does it swing down or something?
Old Mar 21, 2006 | 07:14 AM
markdtn's Avatar
markdtn
Originally Posted by Thmprr
..On another matter, the fuse panel is hard to see, is there a trick I am missing, i.e. does it swing down or something?
No, You just have to turn into a pretzel to see it
To 76 Vette Head light problems
