69 TH-400 Flexiplate Question, Does anybody know...
Cruise-In VI Veteran
Cruise-In VII Veteran
how many teeth the flexiplate for a 69 model with a TH-400 has? Is it 153 or 162? This is in reference to the GM mini-starter post by MIKER a couple of day ago.
Thanx
[Modified by Smokehouse69, 10:14 AM 8/15/2001]
Thanx
Re: 69 TH-400 Flexiplate Question, Does anybody know... (Smokehouse69)
All stock small blocks came with a 153. most if not all mini's can be adjusted for each kind. Also 75% engaugement is good according to my mini-sarter tech line.
Re: 69 TH-400 Flexiplate Question, Does anybody know... (gkull)
gkull-----
I used to think that all THM-400 flexplates were 153 teeth, too. However, I found out differently (much to my embarrassment). As it turns out, 68+ with THM-400 use a 168 tooth ring gear flexplate.
Re: 69 TH-400 Flexiplate Question, Does anybody know... (Joe Lucia)
Thanks Joe!
I have also seen a 168 on a 70's 4X4 pickup. I tend to think it wasn't that common.
I put a 168 on mine, for 20 years and have never had starter motor problems.
